20 Most Recent
Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter Questions & Answers
The right hand side indicator
Hi if when you put the hazzard lights on all the indicators work then this suggests the problem is with the indicator switch, you may need to get it replaced, it could be that it has got corroded due to rain or damp getting in, if the hazzords are working ok then you know the fuse and bulbs are good so all thats left that could be wrong is the switch that works the indicators.
this will need removing and replacing to solve your problem
The kids drove my Pride Legend XL through a
I had a similar problem with my Pride Legend XL when I drove it
through a puddle accidently and some water splashed up underneath
the motor controller. It would buck or go then stoo without any warning
as the electric brake was applied. Had to take the seat off and use a
hair dryer on the controller connections to dry them out. It doesn't
seem to take much water to make these inoperative. After thoroughly
dried out with a hair dryer..no more problems like that with it.
Colt xl8 code 7 fault changed speed pot still cuts out
hi, can i ask you what the pot was like , a electronic one or mechanical one ?If it's Electronic check there is a 24v - + plus voltage on the red and black cable. This is a common problem with these scooters.regardswww.gewizrepairs.co.uk
I have an xl8 mobility scooter that keeps cutting
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned.
Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Hello my pride scooter beeps 6 times which in the
The Legend 4 wheel XL scooter has a S drive controller. This is an assumption based on the model described. I would have to run the serial number to be certain. With the S drive controller a beep code of 6 indicates a bad throttle potentiometer or a throttle potentiometer which is out of neutral on start up. You can test for this by turning off the scooter and attempting to try various neutral positions of the pot, and turning the scooter on with your other hand while maintaining this neutral position. This usually works by trial and error.
The more technical way is to remove the front console covers and inspect the pot mechanism visually checking the spring and movement and electronically using a digital volt meter.
If you do indeed have a code for the charger plugged in (and of course it is not), then you have a bad charger. These chargers are notorious for going into drive inhibit when they burn out and the computer will give a code of charger plugged in. To test for this, you need to remove the cover to get to the charger and unplug the charger on the output side. If the scooter runs you have a bad charger that is stuck in drive inhibit (electronically equivalent to the scooter being plugged into an AC wall outlet). Hope this helps.
I have a legend pride four wheel electric scooter.
Hi. Is the machine display any fault codes, ( flashing battery light)? Is the free-wheel lever in the correct place, Move it in and back again and try it. It is possible that you have a stuck brush in the motor. Get a multi meter and check the resistance through the motor. Check that the brake unit is releasing properly.
If one of the battery lights is flashing, count the flashes and let us know what the pattern is, and we can tell you what it means. Good luck. Neil.
