20 Most Recent
Pride Mobility Products Go Go Ultra X 4 Wheel Questions & Answers
Hi we have been passed
It sounds like the batteries have gone bad and need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours one day a week) of the gel will solidify. What is probably happening is charger light will either stay green, go to green after a very short time, or the charger will be connected for hours or days and the light never changes indicating a full charge. When you turn on the power chair, nothing happens. The charger may indicate the batteries are full, but instead of being full of power, they are full of crud as the gel inside them has oxidized. Since you are the second owner of the scooter, you will need to replace the batteries on your own. Check the owenr's manual for the correct type or contact Pride Mobility at 800-800-8586. Good luck!
My gogo-ultra will not run. it has been stored
hi,
Check the connections between the battery and motor, if the rear come apart check there connections there,
If the connection with the batteries string loaded, rough them up slighty with a wire brush but be gentle and is there freewheel lever right in position for drive.
Regards
GeWiz.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
