20 Most Recent Dell Optiplex 740 Desktop Desktop Computer Questions & Answers
RAM problem. Remove the RAM and reseat
Dell Optiplex... | Answered on Jan 30, 2016
What are you seeing other than this? Are there other problems you see? When do you see this? I have worked on older optiplexes and the lights are yellow at different times.
Dell Optiplex... | Answered on May 16, 2014
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Dell Optiplex... | Answered on May 06, 2014
If the power light is b linking green that usually means the pc is in standby mode. Press a key on the keyboard or move the mouse to resume normal operation.
Dell Optiplex... | Answered on Oct 09, 2013
Please check monitor cables, if ok, then check RAM
hi,
this is probably a no power/nopost problem here is a helpfull link
http://tinyurl.com/d4t55m
further queries are welcome
if you think my solution was helpfull please do rate me
Dell Optiplex... | Answered on Feb 15, 2013
parental control is usually at browser level settings open that up and make adjustments might be under security
other parental controls are usually on user level on pc's but if you are the only one using it and not a child, then that's most likely NOT what you are asking
Dell Optiplex... | Answered on Jun 01, 2012
This model comes in 3 designs for the computer chassis. Small Form Factor Chassis (SFF), Desktop Chassis (DT) and Mini-tower Chassis (MT).
Here is a link to for the Dell Optiplex User's Guide:
http://support.dell.com/support/edocs/systems/op740/en/UG/RP699A03MR.pdf
Dell Optiplex... | Answered on Sep 09, 2011
you can Dowload it from Dell Optiplex 740 driver page
go below the page ,Select the OS you are useing , Select Catagary i.e. "Audio"
Click "Download" on the search result. after file download. Open the file (some files of Dell extracts in C:/ location. setup will Prompt the location. Note down the location, where it is extracting) or Locate the extracted place and run the setup file.
Dell Optiplex... | Answered on Jan 28, 2011
If it shuts off randomly it could be to things it could be power suply or virus. i would first off make sure that there is no viruses. make sure u run a virus scan and there is no viruses. if it turns up none i would look into a power suply. if it still shuts off i would look into making sure the heat sink on your cpu is seated correctly and has good heat sink and fan as it could be over heating
Dell Optiplex... | Answered on Jan 14, 2011
95% sure the computer did not overheat, if it did overheat it will shut down by itself to prevent itself from overheat damage. Crashes or computer freeze could result in lagging due to unpowered computer component. When multitrask as you said, some newer software such as games, burners, media players use alot of memory and cpu power and for that sake the cpu will take more time to process these instruction from the software, Most likely with a optiplex 740 you are dealing with dual core, and the promblem can be associated with your memories. Multitasking is memorie hungry. So you may want to upgrade your memories, if not considering purchasing a more powerful computer to handle those task you are using. Also as a advice you may want to defrag your harddrive to make seeking speed faster.
Dell Optiplex... | Answered on Jan 13, 2011
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
A solid amber power LED indicates a problem with the motherboard, or something attached to it. (I've seen a bad mouse cause a no post before) Disconnect all cables except power, turn on system see if any LED change. If using a UPS, connect power direct to the wall. If still no change, open case, remove any expansion cards, try again. If still no go, disconnect power cables to all drives, try again.
If still no change, then replace the motherboard
Dell Optiplex... | Answered on Dec 25, 2010
Dell Optiplex 740 Desktop Desktop Computer  Logo
43 questions posted
Ekse
Clive
Clive
Alun Cox
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
computer seems overheat when performing
  • Computers & Internet
