20 Most Recent
Everex CloudBook CE1201V Netbook Questions & Answers
Change memory Everex CE1200V
Your Everex CloudBook
can support up to 1024MB (1GB) of computer memory. For optimal
performance install the maximum amount of memory in each socket., Your Everex CloudBook uses PC2-4200 type memory.,remove the battery than remove all ten screws than with a credit card u should flip from side to side the cover off
Nao estou conseguindo driver para
Aqui puede conseguir todos los drivers para su computador:
(Copia y pegue al navegador)
http://cloudbookumpc.com/everex-cloudbook-ce1200v-documentations-user-manual-setup-guide-and-windows-xp-drivers
¡Permita por favor que sé si esto fue útil y si resolvió el problema! También si la información proporcionado fue útil, por favor clic en los pulgares apropiados hacernos enterado que el problema ha sido dirigido o que la información proporcionado le ayudó con el problema.. Gracias y la buena Suerte.
I turn it on and
Time to reach for your rescus disc or system dic to boot from if F8 doesn't let you in to safe mode.
Hope you can recover OK and when you are in run CHKDSK/F to check for hard drive errors.
Need to know if there is a alternate site that has
I found some Everx recovery disk on Ebay I am not sure if the disk will accommodate
your Netbook PC. Most recovery disk have the same information store to them.
Here is the site / You may need an eBay account to purchase or someone you know will
have to order for you.
I hope this helps. Have a good day!
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1313&_nkw=Everex+software&_sacat=See-All-Categories
Forgot password
you can download a boot cd called ophcrack.
Burn this to cd anfd boot from there.
This cd will find your password...
HELP
Just trying a stick of RAM shouldn't kill your system. Think dirt. Is there a chance that the contacts on both the laptop and RAM are dirty? Are you sure that you installed it correctly? It's easy to get it wrong in a laptop. It's real easy.
Everex ce1200v won't except username and password
Go to Control Panel, select Add or remove user account, select The User Name with the Password, under Administrator or Guest acccounts. You can change the User Name and Password. I hope thise Fix it.
I am trying to get a \r\nWIfi network connection.
Hi.
Both HTTP and FTP use the same network protocol to transfer data (TCP/IP).
FTP regular port is port 21. By default this port is left open by the router built in firewall, and on firewalls installed on Windows. Unless the router or another firewall has been specifically set to block port 21, firewalls will not block FTP on standard settings.
FTP may be not working because of the client used. The regular browsers do not allow full usage as FTP client.
Try first downloading an FTP client like filezilla. Click here to download.
You can also test the network using the computer on a different wi fi, and checking if you have the same problem (HTTP but no FTP) using a different local network.
If the problem is not the FTP client, then please come back to us telling what error you get, and telling us what happens when you connect to the network using a cable.
