20 Most Recent
Tomtom ONE v3 Car GPS Receiver Questions & Answers
Error calling method on NPObject (TOMTOM GO)
Received same error when trying to operate my TomTom Go from PC. Fixed
this by deleting (or renaming) file install.rdf. File can be found in
Windows 7 in:
C:\gebruikers\
username\AppData\Roaming\TomTom\Profiles\
randomname.default\Extensions\Navcore.
versio[email protected]
Delete or rename the install.rdf file and try to operate your Go again
from TomTom Home. It will ask to install some software, reply OK and
you're done.
Tom Tom only has Guam map since update
That is really strange!
I can only suggest that you verify what MAPs are physically on your TomTom device by connecting it to a PC/LAPTOP and use Windows Explorer to look at your GPS drive folders: should see a folder for each 'country' (like GUAM).
The normal way to check which maps are registred and loaded on your device is to use TomTom Home -> Update maps function: it will show you the status or whereabout of any Maps that you have loaded or backup and which one can be purchased.
Hope it helps: let me know how you go.
ps.i f you wisely backup your device on a regular basis (via TomTom Home or direct copy to your PC/LAPTOP), you could always RESTORE FROM BACKUP and start again.
When switched on green light next to switch flickers but that is all
It sounds like the TomTom isn't able to boot up. This may be due to a software or data issue.
Have you tried to (use HOME on your computer to) connect to the TomTom server ? to update the software/data, and/or tried to restore the software / data with the (previously) backed-up copy (that you had previously saved on your computer) ?
How can I set time?
You can set (or reset) your Time (& display format) using the "Menu".
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
1. To set Time:
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
How do I update maps on tom tom one from computer to GPS ?
Usually, you connect your TomTom to your computer, and use the TomTom software (e.g. HOME) to update (e.g. buy, download and install) your map(s).
If your question is about how to copy a (new / another) map on your computer to your TomTom device (i.e. without using the TomTom HOME software), you can simply copy the "map" folder (of the map on your computer) to your TomTom Device (that you've connected to your computer).
You may have other questions like, is there enough memory on your TomTom device for the map ?; is the (new/other) map version compatible for the TomTom (model/version) device that you have ?; is the map "activated" to run on your TomTom device? etc.
