20 Most Recent
Belkin F5D9630-4A Wireless Router Questions & Answers
Hello, I have a Belkin
hi mate, i would just hard reset the router and then you can use the default password that comes with it , below is the link to the belkin hard reset proceed, and i diagram of your router, just hold a paperclip in the reset button for 15 seconds (fig. 10) after its reset you can use the default password the router came with,
here is the hard reset procedure
Resetting the Belkin router to factory default settings using the Reset...
the default password should be on the router on a sticker somewhere
4/19/2017 10:47:20 AM •
Belkin...
Answered
on Apr 19, 2017
Password to wifi
If you've reset the router back to factory (done by holding reset button for 5 secs) the password is blank. access it by entering 192.168.2.1 into your web browser. Here's a manual in case it's needed at any point http://cache-www.belkin.com/support/dl/f5d9630-4_p75125uk_a.pdf
9/6/2011 4:01:51 PM •
Belkin...
Answered
on Sep 06, 2011
When i turn my computer
When you turn the computer OFF and the computer's Network Iterface Card (NIC) LED goes orange it means that it is a sleap (meaning that it could wake up from a remote command from an other device/computer) NOT THAT OTHER DEVICES ARE NOT CAPABLE OF USING THE NETWORK... now I need more information on your setup, (like), is the computer (the off computer) a DHCP SERVER???, is it set up to SHARE the internet connection with other devices (is it the network's gateway)??? or (DNS SERVER)??? when did this problem poped up... after a Windoze update??? did it worked befor and stoped for no reason??? what kind of modem you have??? who is your ISP (Internet Service Provider)???
You need to feed me to help you!!!!
9/1/2011 12:42:01 AM •
Belkin...
Answered
on Sep 01, 2011
How to install Belkin router without cd
You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1/29/2011 6:17:21 PM •
Belkin...
Answered
on Jan 29, 2011
I'm changing ISPs and in trying to connect to the
On the back of the router locate a small hole with letters "RESET".Press gently for 30 seconds and wait for reboot.Then log onto http:/192.xxx.xxx and start anew configuration.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
11/30/2010 6:39:41 PM •
Belkin...
Answered
on Nov 30, 2010
I have a Belkin F5D9630 wireless router and
since one of the computer is going w/l, that means router should be working fine. the computer that is not connecting might have some w/l settings that neds to be changed
1/16/2010 5:27:11 PM •
Belkin...
Answered
on Jan 16, 2010
My belkin f5d9630-4 will not connect to internet
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
1/12/2010 1:24:52 AM •
Belkin...
Answered
on Jan 12, 2010
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
