20 Most Recent
Boston Acoustics Horizon Solo Clock Radio Questions & Answers
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Tuner doesn't work
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off.
