20 Most Recent Peg Perego Gaucho Superpower Questions & Answers
I have a peg perego gaucho grande and used the kids wheel overhaul kit two months ago and just today removed the pin for the high low function ... Now my gaucho does this choppy sound when in low spee
sounds like you have some broken teeth in one or both of your gear boxes, see which side the sound is coming from, and you can either open the gearbox and remove the broken teeth or just buy a replacement gearbox
8/16/2017 2:33:19 PM • Peg Perego... • Answered on Aug 16, 2017
2answers
24 volt Gaucho will run a few feet than stop.
It's your circuit board / breakers that are doing that, as perego quotes, to keep it from destroying the gears if they get overheated. It's $100+ for a new one thru them. Check out the site modifiedpowerwheels.com , many people convert these to run off scooter controllers (like I did to ours).
10/24/2014 9:44:21 AM • Peg Perego... • Answered on Oct 24, 2014
2answers
Green and red battery lights blink--wont run
I have the same issue. Called their customer service and they said it was a defect in the charging system. They are sending a upgrade kit for free, but when it's installed you can't charge the battery using the rear port anymore. No big deal. I'll report back when the fix is complete. 5-7 days until it gets here.
6/23/2014 5:50:47 PM • Peg Perego... • Answered on Jun 23, 2014
My Thomas 6v Ride -On Train works, but VERY slow.
It sounds to me like your battery needs to be replaced. The batteries lose their ability to hold a full charge after some time (especially if they've sat for a long while without a charge). You can get the battery tested at a trusted shop, but it might be more econimical to just replace the batteries with fresh batteries and see if that solves the problem. New batteries will charge much better and hold the charge much longer.
9/26/2013 5:53:21 PM • Peg Perego... • Answered on Sep 26, 2013
0answers
2answers
Very slow 2nd hand peg perego gaucho
1/11/2013 3:38:19 AM • Peg Perego... • Answered on Jan 11, 2013
0answers
Electrical
Be the first to answer 7/4/2012 6:26:54 PM • Peg Perego... • Posted on Jul 04, 2012Be the first to answer
How to attach wires on a lead acid baterry
usually they are soldered on
5/22/2012 4:20:59 PM • Peg Perego... • Answered on May 22, 2012
Charged battery after useing it
I think your circuit board needs replaced...you can get it at tigerimports.com My son's 24 volt polaris did the same thing
11/7/2011 10:34:50 PM • Peg Perego... • Answered on Nov 07, 2011
Hi where can i puchase a mother board mecs0004 as
10/24/2011 11:33:10 AM • Peg Perego... • Answered on Oct 24, 2011
HI all, Purchased a new
Sounds like the master controller circuit board to be found under the seat. If you;re in Europe, get in touch with Wacky Wheelers at http://www.wackywheelers.com
9/23/2011 12:42:27 AM • Peg Perego... • Answered on Sep 23, 2011
Red and green lights both
It could well be the master controller circuit board that is faulty - its the one underneath the seats. If you're in Europe - get in touch with Wacky Wheelers at http://www.wackywheelers.com/shop and they could supply you with a new one
9/22/2011 11:52:07 PM • Peg Perego... • Answered on Sep 22, 2011
Hello, after winter pause now
Most likely is the battery, if not maintained properly the battery will die if left uncharged for a few months. The Superpower has a controller much like a scooter controller, built into the controller is a low voltage shut off. If the battery is not providing at least 21.5V under load, it will shut down and not move.
Do an ebay search for RBC6 batteries and get 2 12V 12ah batteries, wire them in series to get 24V and use the yellow connector to connect it to your Super Power. You should be able to get them shipped to your door for around $44 vs paying $125 for the Peg original.
5/3/2011 9:47:16 PM • Peg Perego... • Answered on May 03, 2011
0answers
Our Super Gaucho 24volts is
Unfortunately the batteries just lose their holding power after awhile, and if you don't keep them charged every few months (like during winter if your child isn't riding, you still need to charge / refresh the battery every 2 months or so, if it isn't charged for a few months, it'll lose some of it's holding power), that's a very common problem. Our 24V Perego batteries for our Gaucho only seem to last like 30 minutes of constant riding (my son rides non stop sometimes for 30+ minutes). If you check out the site modifiedpowerwheels.com , people convert them to use non Perego batteries that run for much longer!
11/18/2010 5:01:26 AM • Peg Perego... • Answered on Nov 18, 2010
Peg perego drivers side back wheel not working
It's probably your gearbox or motor that isn't working, all available thru pegperegoparts.com or thru Perego itself.
11/18/2010 5:00:08 AM • Peg Perego... • Answered on Nov 18, 2010
I think I have a bad battery... What should the
If you use a multi tester, it should come up at 24 volts or 25 volts on the meter, if it's less than that, then the battery isn't going to work anymore.
11/18/2010 4:57:22 AM • Peg Perego... • Answered on Nov 18, 2010
Peg Perego Gaucho Superpower Logo
44 questions posted
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
our super gaucho 24volts
  • Toys
