20 Most Recent Frigidaire FDL50R1 Dehumidifier Questions & Answers
Read the instruction manual thoroughly and ensure you did everything exactly. If it still doesn't work it is faulty and should be returned.
Frigidaire... | Answered on Jan 29, 2018
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Frigidaire... | Answered on Dec 06, 2014
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Frigidaire... | Answered on Sep 16, 2014
Hello friend, that's a great question!
The best way to clean your Frigidaire dehumidifier's coil is by using a brush attachment from your vacuum. I hope this is helpful. -Matt
Frigidaire... | Answered on Aug 26, 2014
Hey friend, thank you for the post!
I understand that your dehumidifier continuously is set at 50-60 and the clean filter light has not stopped. I would like to ask you some additional questions in order to provide you better assistance. First, does the appliance still collect water? Secondly, have you tried to reset the appliance? I look forward to your comment back so that I can further help you. -Matt
Frigidaire... | Answered on Jul 31, 2014
Hello Friend, this is Z. I am happy to assist you!
If you are receiving an error code AS on your Frigidaire dehumidifier, it typically means that your dehumidifier is experiencing a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual appliance replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
Frigidaire... | Answered on Jul 29, 2014
I understand that you want to know how to measure the humidity in a room with your Frigidaire dehumidifier, model# FDL50R1. Typically, your appliance will not measure the humidity and tell you exactly what the level is. I suggest placing your dehumidifier in the room you want it in, and turning it on to the continuous mode. The display will show "CO". Leave it at this setting for the first 3-4 days. Once the 3-4 days has passed, I suggest setting it to the 50%, 60%, or 70% setting and change it to your liking. If it is more humid in the room than you would like, put the setting lower. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on May 29, 2014
will not come on screen is blinking stop
Frigidaire... | Answered on Jan 08, 2014
Hi Kim - I understand that you removed the styrofoam inside the dehumidifier float thinking it was packing material, however I would recommend contacting the manufacturer to verify if it the part is available and can be replaced.
Frigidaire... | Answered on Sep 19, 2012
CO means Constant On
Frigidaire... | Answered on Sep 01, 2012
Frigidaire FDL50R1 Dehumidifier Logo
80 questions posted
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Andrew Taylor
Andrew Taylor
STEVE
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dehumidifiers
Most Popular Question
thought styrofoam inside dehumidifier
  • Dehumidifiers
