20 Most Recent
Compucessory CCS 60062 Shredder Questions & Answers
Yellow light
Try soaking the blades with some lubricant and leaving for a while then try running in reverse it should solve the problem, youight need to repeat the process 2-3 times for the best results
How do you empty the container?
You will first need to unplug your shredder. On either side on the shredder head, there are grooves. These are finger grooves. Place your fingers inside the finger grooves and lift up. This will remove the shredder head from the waste basket. Simply empty the waste basket, replace the shredder head and plug back in.
Was shreeding paper and it stopped? cleand it.
some of the new shredders do that so you should get a shredder that has a warrenty so if this happens again you dont have to worry about haveing to buying or fixing the shredder because when you try to fix these type of machines you ether end up just causing the machine to be comepletly unusable or it works of a little wile and u have to try to fix it again instead i advise you buy a replacement Fellowes® PS-79Ci doesnt jam and can dice 12 sheets of paper
hope this helps
How do these points equate to money?
No money ever!
There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun.
ADMIN Andrew
- Answers: 65,820 and not a penny per Answer.
Head over to
www.justanswer.com they pay lots of money because they charge for people to ask a question.
