20 Most Recent Sanyo VPC-HD1010 Camcorder Questions & Answers
0answers
manual
0answers
I lost the docking station.
buy one
4/4/2011 4:44:32 AM • Sanyo VPC-HD1010... • Answered on Apr 04, 2011
0answers
2answers
When i plug my camera into the HD tv via HMDI port
On my HD Tv, I have to press the "Input" button on the remote - and that displays a list on the screen.... Aux, TV, PC, Game, HDMI. Find the equvalent button on your TV Remote and select the HDMI port as the "Input" and you should be good to go.
2/2/2011 2:01:27 AM • Sanyo VPC-HD1010... • Answered on Feb 02, 2011
Buzz on internal microphone setting. Audio still
I agree that you're having a grounding problem concerning the built in mic. This could be caused by a cracked or broken solder joint on the circuit board, or ribbon connector, if used, but usually condenser mics are wired. You'll have to get in there and look around carefully for the problem, or workaround it by using the external mic.
One more thing to check is that the jack for the external mic is good, and it's solder connections, since in it's "open state", the contacts have to be short-circuited to the internal jack assembly.
Anyway, it's probably some physical problem, versus software, so keep investigating that route.
Good luck, and hope this helps.
2/2/2011 1:57:14 AM • Sanyo VPC-HD1010... • Answered on Feb 02, 2011
0answers
Sanyo VM-EX220P 8mm Video Camera. Hello my camera won't play any of my cassettes. It all comes up scrambled?!
Question edited for a lot more clarity. Question moved from Televisions category. When was the last time the head was cleaned? It may also need servicing or Adjustment.
Sanyo VM-EX220P Adjustment Manual
https://www.manualslib.com > ... > VM-EX220P View and Download Sanyo VM-EX220P adjustment manual online. 8 mm. VM-EX220P camcorder pdf manual download. Also for: Vm-ex370p, Vm-ex280p. ..
6/26/2023 6:37:46 PM • Sanyo Video... • Answered on Jun 26, 2023
Hi i have a sanyo hi 8 camcorder 25 plus years old and it loads and ejects and tape flashes continually whats the oroblem
It sounds like your Sanyo camcorder may be experiencing a problem with the loading or ejecting mechanism. This could be caused by a number of issues, including a damaged or broken cassette mechanism, a malfunctioning loading or ejecting motor, or a problem with the camcorder's control board. To troubleshoot the issue, you could try the following:
  1. Make sure the camcorder is clean and free of any debris or obstruction.
  2. Check the cassette for damage, such as broken or bent spindles, and make sure it is properly seated in the camcorder.
  3. Try using a different cassette to see if the problem persists.
  4. If the problem persists, you may need to have the camcorder repaired by a professional.
Keep in mind that due to the age of your camcorder, it may be more cost-effective to purchase a new one rather than repair the old one. However, if the camcorder has sentimental value or is no longer in production, repair may be the best option.
1/2/2023 6:16:38 PM • Sanyo Video... • Answered on Jan 02, 2023
Sanyo VM-D66P error: CASSETTE
There is a pulley that breaks inside but as these have been obsolete for over 20 years, I doubt it is repairable any more. Fully working VM-D66p for £30 on amazon or fleabay.
2/3/2022 1:35:20 PM • Sanyo Video... • Answered on Feb 03, 2022
Hello, I have a sanyo vm d66p camcorder and want to play it through a tv. What cables do I need ? thanks in advance
You need the RF Adapter cables. I have seen items like that at thrift stores. The camera has that barrel connector with 6? pins to connect it to the converter box that output to Channel 3-4. Keep checking ebay or craigslist. https://www.manualslib.com/manual/894346/Sanyo-Vm-D66p.html?page=2#manual https://www.ebay.com/itm/Sanyo-VM-D6P-8mm-Video-Camera-Bundle/163512488835?hash=item26121a9383:g:pLYAAOSwUMBb8MfJ:rk:1:pf:0
2/6/2019 4:14:21 AM • Sanyo Video... • Answered on Feb 06, 2019
0answers
Sanyo VPC-HD1010 Camcorder Logo
15 questions posted
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
lost docking station
  • Video Cameras
