20 Most Recent
Aiptek ISDV2.4 Flash Media Camcorder Questions & Answers
Deleted dcr
What is recording medium in your camcorder? Memory card, hard drive, built in memory? If memory card or hard drive then remove it from camcorder, connect to computer and use recovery software. Hopefully camcorder doesn't do full format only quick format. If full format was performed then say good bye to your recordings. I don't kow if any recordings on internal memory can be recovered.
Hello, i have an Aiptek cam corder and the screen
i think you will have to buy a new camcorder because if it is creeping out like that it is probably the camera itself,well the crack has something to do with it also,but its the camera,if it was just a crack itself on the camera then you can replace it,if you didnt keep touching it after it cracked it probably would have been alright to just get a new screen,but now its messed up...
No batteries work
Have you tried to use it connected to a power supply, to verify that it is in fact in working order?
I can't get flash to work on my camera
Make sure you have good strong batteries. "Strobe Charge" is what the camera says when it's sending power to the strobes that make the flash. It can take alot of juice and if you're using weak or old batteries they may not be able to handle the load.
I found with my DSLR that the Energizer Lithium batteries are great for cameras and have been using those exclusively in all my cameras. I just got the Aiptek about a month ago, have not changed batteries yet. My other digital video camera ran for over two months on one set of them, and I used it alot. It's on it's second set now and my husband has it.
