20 Most Recent Samsung SC-DX103 DVD Camcorder Questions & Answers
Hi. this unit will need to be serviced by the manufacture. this is a major disk error that has occurred. there is one or more corrupted sectors on the hard disk that is used for recording. Unfortunately, you have lost all dated at this time. Contact Samsung for this repair.
Samsung SC-DX103... | Answered on Jun 14, 2019
what discs are you using as they need to be compatible with the recorder, some discs are one time recording others are + or - and some are rewritable, there is also settings for format that have to be set for the discs.
Samsung SC-DX103... | Answered on Nov 26, 2017
friend,you should read the catalogue.
Samsung SC-DX103... | Answered on Mar 27, 2013
Yes you can. Final Cut Pro supports almost all types of video format.
Samsung SC-DX103... | Answered on Sep 02, 2011
Try pulling the battery out and putting it back in then charging it. If that doesn't help anything sounds like you have a battery that needs to be replaced.
Samsung SC-DX103... | Answered on Aug 21, 2011
You can download the manual from the manufacturer's web site at
http://downloadcenter.samsung.com/content/UM/200809/20080911134044218_SC-DX100_ENG_IB_0725-B.pdf
Samsung SC-DX103... | Answered on Aug 09, 2011
Hi if you do not have the manual, suggest you download from samsung. Same thing happened to me, you know what have forgotten already!!
I did same, free download copy of the unit's manual. Get their addres through google, just type in samsung.
Samsung SC-DX103... | Answered on May 12, 2011
Best thing to do is to order a replacement disc from Samsung. Unfortunately, these files are licensed so you cannot just download it anywhere. Give Samsung a call and ask them to send you a replacement disc.
Samsung SC-DX103... | Answered on May 05, 2011
Try formatting the SD card using your computer. Insert the SD card in your computer. Open My Computer, find your SD card drive, right click on it and select Format. Choose FAT for the filesystem and continue with the format. When the format is complete, insert the card into your DVD Camcorder and try again.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Samsung SC-DX103... | Answered on Feb 22, 2011
Symptom indicates problem of ccd imager chip failure in camcorder that is why no live image in camera mode for fresh recording.
Please replace ccd imager chip in camcorder to solve this problem, local camera repair shop will do this job because camcorder will take apart and soldering work is required for ccd imager chip replacement.
Hope these info will help you.
Thanks.
Samsung SC-DX103... | Answered on Feb 18, 2011
Th3an:
The manual is available here (click here for user manual).
About "Write Error" is says:
Your disc or memory card has some problems in writing data. Disc is shocked while movies is being recorded onto the disc.
To fix the error it says:
To recover previous data in your disc or memory card, turn the power off and on. After recovering data, the system will be switched to STBY mode. If it fails to recover data, "Disc Error" or "Card Error" appear.
Apparently if you get "Disc Error" then the disc has become unusable.
If you have any questions please ask. Thanks for using FixYa
Samsung SC-DX103... | Answered on Jan 31, 2011
You can get the download on the link below.
http://dv-media-pro-2.2-samsung.fyxm.net/
Good Luck
Samsung SC-DX103... | Answered on Dec 01, 2010
Samsung SC-DX103 DVD Camcorder Logo
91 questions posted
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
View Most Popular
SC Samsung
  • SC Samsung
Most Popular Question
both viewfinder
  • Video Cameras
