20 Most Recent
Canon ZR900 Mini DV Camcorder Questions & Answers
How do I load a
You require a firewire cable, 4 pin to 6in, these are also cazlled i link or IEEE 1394.
iMovie should be on your Mac, captue with that unless you have FinaL Cut, Adobe etc..
Al
My camera will not play
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
v
Cannon ZR900 will not power off
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
When i try to play back a tape on my cam it shows
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
When i insert a mini dv tape into the tape deck it
This is a tape drive motor component failure
Why does my canon zr80,
This is usually caused by a defective component in the tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Won't playback
Porblems can be many, if can be failure of the servo, the capstan and drum servo, the problem with a mechanical jamming,
the problem of the rollers or failure of reel sensors, drive motors.
So unless you check them one by one we cannot finalise.
My camera got knocked over while filming
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
My canon zr90 keeps saying
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
Hi i inserted a cassete
This is usually caused by a defective component in the tape detection circuitry and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
When put in a new
Perrhaps the pinch roller is chewing up the tape and is guiding it down.Look for possible dirt on the drum. the tracks or the roller. Also check for free movement of the idle rollers and action of the take up spool. Make sure that the tape is of good quality.
