20 Most Recent Kenmore Bagless Upright VacuumVacuum Questions & Answers
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
3/21/2012 1:05:24 AM • Kenmore Bagless... • Answered on Mar 21, 2012
Where can I find a
I advised the customer of part number LIT4370069, which costs $9.99 at searspartsdirect.com. T customer advised me that he needed a service manual and troubleshooting because he is not getting any suction. The customer is going to try and get assistance from another expert.
9/11/2011 9:44:50 PM • Kenmore Bagless... • Answered on Sep 11, 2011
0answers
Removing and installing the pedal in kenmore upright vacuum cleaner - part no. 8174906; model no. 116.31912100
I don't have specific information on the Kenmore upright vacuum cleaner model number 116.31912100 or the part number 8174906, but I can provide you with general guidance on how to remove and install pedals on some vacuum cleaner models. Keep in mind that procedures may vary between models, so use the following as a general guide:
Removing the Pedal:
  1. Unplug the Vacuum Cleaner: Ensure the vacuum cleaner is unplugged to prevent any electrical accidents.
  2. Turn the Vacuum Cleaner Over: Lay the vacuum cleaner on its back so that you have easy access to the underside.
  3. Locate the Pedal Assembly: Identify the pedal assembly on the underside of the vacuum cleaner. It is usually connected to the height adjustment or other features.
  4. Release Tabs or Screws: Look for tabs or screws securing the pedal assembly in place. Use a screwdriver or the appropriate tool to release these tabs or screws.
  5. Disconnect Linkages: Some pedal assemblies are connected to linkages that control various functions. Disconnect any linkages carefully.
  6. Remove the Pedal Assembly: Once the tabs, screws, and linkages are disconnected, carefully remove the pedal assembly from its housing.
Installing the Pedal:
  1. Position the New Pedal: If you are replacing the pedal, position the new pedal in place.
  2. Reconnect Linkages: If your vacuum cleaner has linkages, reconnect them to the appropriate points on the new pedal assembly.
  3. Secure the Pedal: Use screws or tabs to secure the new pedal assembly in place. Make sure it is securely fastened.
  4. Test the Pedal: Manually operate the pedal to ensure that it moves smoothly and engages the desired function.
  5. Turn the Vacuum Cleaner Upright: Once the pedal is securely in place, turn the vacuum cleaner upright and plug it back in.
If you're uncertain about any steps or encounter difficulties, it's recommended to consult the user manual for your specific model or contact the manufacturer's customer support for assistance. They may provide detailed instructions or guidance tailored to your vacuum cleaner's model and part.
11/19/2023 8:55:35 PM • Kenmore Vacuums • Answered on Nov 19, 2023
Where can I find a kenmore intuition vacuum repair manual
There isn't one! I checked yesterday when I answered your first question. https://www.google.com/search?q=Kenwood+bu4022+service+manual ..
4/7/2023 4:54:00 AM • Kenmore Vacuums • Answered on Apr 07, 2023
Hose assembly model # on 11621714110
The hose assembly model number 11621714110 is a genuine OEM (Original Equipment Manufacturer) part for use with a variety of appliances, including vacuum cleaners and washing machines. This hose assembly may be used to connect various parts of the appliance, such as the pump and the tub, or to connect the appliance to a water source. I hope this information is helpful! Let me know if you have any other questions.
1/4/2023 12:56:42 PM • Kenmore Vacuums • Answered on Jan 04, 2023
What's the cubic square footage of Kenmore 253 28432809
Hi, I'm getting 13.7 cubic feet. To reconfirm, you can call kenmore customer service by dialing 1-844-553-6667. Thank you.
10/12/2022 12:19:08 AM • Kenmore Vacuums • Answered on Oct 12, 2022
2answers
How to replace a circuit board on Kenmore Vacumn model 11621714111
More likely to be a bad connection or brushes on the motor that need replacing. Classic symptom of bad / worn brushes.
8/19/2022 7:50:09 AM • Kenmore Vacuums • Answered on Aug 19, 2022
2answers
Kenmore air cleaner model # 43783252 quits running
Press and hold the filter reset button for 3 seconds to reset the indicator. The control may need to be replaced if it isn't able to reset. [url=http://spacebarcounter.org]Spacebar counter[/url]
8/7/2022 9:32:59 AM • Kenmore Vacuums • Answered on Aug 07, 2022
THe retractable cord of my Kenmore vacuum is stuck Inside, I removed the filter cover, the 2 screws but cannot pull out the cover to access the cord compartment
Thank you very much. I'm up and running again. My retractable cord jump track and got stuck. Thank you thank you. And I did it myself with your directions. Linda
7/26/2022 8:39:04 PM • Kenmore Vacuums • Answered on Jul 26, 2022
2answers
I have a Kenmore canister vacuum. The problem is the the attachment called Pet Powermate doesn't spin very well
It isn’t the belt. Hair builds up in other places besides the brush. The device is made to come apart. Take it apart an clean out both ends on the shaft of roller brush. Remove tangled hair on the shaft and the brushes.
7/5/2022 9:47:40 AM • Kenmore Vacuums • Answered on Jul 05, 2022
Kenmore Bagless Upright VacuumVacuum Logo
5 questions posted
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Vacuums
  • Kenmore Vacuums
Most Popular Question
kenmore vacuum cleaner 175 3866180 bags
  • Vacuums
