20 Most Recent Tomtom ONE XL GB Car GPS Receiver Questions & Answers
My tomtom fell on the floor and i get aflashing red and white cross. How do i correct this and get my device working again?
Internal memory was damaged when dropped.. OR the SD card if it has one. Replace the sd card and copy data over from back up
3/8/2014 4:32:44 PM • Tomtom ONE XL GB... • Answered on Mar 08, 2014
manual
When i turn on tomtom
Hello
In rare cases, your TomTom ONE/XL/XXL navigation device may not start correctly
or may stop responding to your taps.
First, check that the battery is properly charged. To charge the battery, connect
your device to the car charger. It can take up to 2 hours to fully charge the
battery.
If this does not solve the problem, you can reset the device. To do this, press
and hold the On/Off button for 15 seconds and release the button when your
device begins to restart.
Before you use your ONE/XL/XXL for the first time, it's a good idea to charge
it fully.
The battery in your TomTom ONE/XL/XXL navigation device charges when
you connect it to the car charger or to your computer.
There is no charging light on your ONE/XL/XXL. To check the battery status
and see when your ONE/XL/XXL is charging, switch on your device and tap
the bottom right-hand corner of the screen in the Driving View. The battery
status is shown on the next page.
When you connect your device to a computer, you are asked if you want to
connect to the computer. If you select No and then do not tap the screen
within three minutes, the device will automatically switch off. This happens so
that the battery can charge faster.
Note: You should plug the USB connector directly into a USB port on your
computer and not into a USB hub or USB port on a keyboard or monitor.
OK.
3/24/2011 8:17:27 AM • Tomtom ONE XL GB... • Answered on Mar 24, 2011
Don't know the location of serial #
touch the screen where the gps signal meter is then touch where it says v7.xx v8.xx v9.xx that appears on the new screen then i will give you the serial and version numbers
2/15/2011 12:37:30 AM • Tomtom ONE XL GB... • Answered on Feb 15, 2011
Hi Good Morning, i
9/28/2010 1:27:16 PM • Tomtom ONE XL GB... • Answered on Sep 28, 2010
Touch screen does not respond tomtom one xl sat
Looks like the touch screen may need replacement. There is a third party tomtom Repair service that will replace the part. If you want to do it yourse, there is a tomtom repair guide , the screen is available on ebay.
7/13/2010 3:08:14 AM • Tomtom ONE XL GB... • Answered on Jul 13, 2010
Change time
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> --> Question Setting the clock Answer To select the type of clock that is shown and set the time, tap Change preferences > Set clock.
This feature is only available on your navigation device. You cannot use this feature in TomTom HOME.
  1. The easiest way to set the time is by tapping the Sync button. Your navigation device will then take the UTC time and date from GPS information.
    Note: You can only use Sync if you have GPS reception, so you cannot set the clock in this way when you are indoors.
  2. Adjust the hours depending on your time zone. Your navigation device works out your time zone and always keeps the time correct using GPS information. You only need to adjust the daylight-saving time.
2/4/2010 4:50:06 PM • Tomtom ONE XL GB... • Answered on Feb 04, 2010
2answers
Turning off tips in tom tom xl 330 s
tap map screen, the tap change preference. then scroll to page 5 i think. then there is a icon that says hide tips.
1/3/2010 2:25:17 AM • Tomtom ONE XL GB... • Answered on Jan 03, 2010
Turn off tips
Just unplug from the car, or ther should be a slide switch on the top of the unit to turn it off.
12/27/2009 4:47:59 AM • Tomtom ONE XL GB... • Answered on Dec 27, 2009
0answers
0answers
The tomtom one screen stays on doesnt load the gps
You can download the clearflash tool from TomTom, and try using it. It may or may not be your problem.
9/12/2009 11:59:28 AM • Tomtom ONE XL GB... • Answered on Sep 12, 2009
How do you put a space when enetring a postcode.
You don't need to put a space in the postcode on a Tom Tom. Just type it all in one line.
8/21/2009 8:03:47 PM • Tomtom ONE XL GB... • Answered on Aug 21, 2009
Slow to find a satalite signal and sometimes not
try updating with the latest GPSfix updates via the tomtom home software
8/15/2009 10:46:16 PM • Tomtom ONE XL GB... • Answered on Aug 15, 2009
What does this symbol mean?
it means that cars are not allowed along the road.
1/15/2009 3:50:34 AM • Tomtom ONE XL GB... • Answered on Jan 15, 2009
When switched on green light next to switch flickers but that is all
It sounds like the TomTom isn't able to boot up. This may be due to a software or data issue. Have you tried to (use HOME on your computer to) connect to the TomTom server ? to update the software/data, and/or tried to restore the software / data with the (previously) backed-up copy (that you had previously saved on your computer) ?
10/16/2018 6:30:46 AM • Tomtom One GPS • Answered on Oct 16, 2018
Update Installation freezes on my TomTom VIA 1500.
hello chack this link Tom Tom wont turn on fix
7/12/2017 2:36:51 AM • Tomtom One GPS • Answered on Jul 12, 2017
Tomtom ONE XL GB Car GPS Receiver Logo
21 questions posted
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
View Most Popular
One Tomtom
  • One Tomtom
Most Popular Question
change time
  • GPS
