20 Most Recent
Kenwood KDC-BT838U Car CD Player Questions & Answers
Hands free phone stopped working
When I had this problem, I just held down the reset button on the face underneath the volume knob (look in the manual if you can't find it). It erased all of my visualization preferences, date, and time settings, but kept everything else and now my bluetooth works again. I hope this isn't something that happens often, cause it will get annoying to constantly be resetting the date/time and other stuff.
3/31/2011 2:35:44 AM •
Kenwood...
Answered
on Mar 31, 2011
My battery mest up so i had to buy a new one now
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
push buttom "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode!
3/16/2011 12:55:30 AM •
Kenwood...
Answered
on Mar 16, 2011
I plug in my kenwood cd player and it says enter
There are a few types of override procedures for Kenwood.
Type 1
that “…” disappears).
Type 2
Type 3
Press
display.
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
"TRACK UP BUTTON" for 3 seconds.. and youre done.
2/20/2011 4:28:19 AM •
Kenwood...
Answered
on Feb 20, 2011
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem. Callers can hardly hear me.
I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls. You can choose the Left Front Speaker, the Right Front Speaker or Both. Check the manual and make sure its set to both.
Regards,
Charlie
2/12/2011 5:00:17 PM •
Kenwood...
Answered
on Feb 12, 2011
Device registry full
The only solution I've found to this is to do a reset by depressing the reset button on the face with a pen and setting everything up again.
2/12/2011 4:53:49 PM •
Kenwood...
Answered
on Feb 12, 2011
Cant set the time on it
First your reciever must be in standby mode. Then, hit the menu button next to the directional joystick on the left. Scroll until you find "clock adjust" and then set the time with the joystick on the left.
1/23/2011 9:16:22 PM •
Kenwood...
Answered
on Jan 23, 2011
Replacing car battery .now my
I think you have to hold 1 and 6 for 15 seconds or so . look for a default code from the factory in your book. I find this procedures... KENWOOD SECURITY CODE CLEAR procedure
These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit. Your radio will require one of the following procedures.
Type 1
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( ... ) should "disappear".
Type 3
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode! If this dont work, I suggest call Kenwood or an authorized service center.
1/9/2011 1:39:39 AM •
Kenwood...
Answered
on Jan 09, 2011
