20 Most Recent
Sony DCR-DVD610 DVD Camcorder Questions & Answers
Movie recording disabled
You have to "close session" on the disk before it will play anywhere else but the camera. Same goes for a CD or DVD you make on your PC. It will play on your PC ok but not on any other player
How do I download video to my computer
Install the driver of the camcorder to the PC and then run the program . Now connect the camcorder and you need to go according to the interactive window display.The recorded memory can be transferrred and saved to a marked folder and copied to a DVD disc from the PC.
I want to copy my
There are free downloads of the info. the disc will have had on it from Sony's Customer Support section of theuir website.
I have an error message
Error code 61:00 indicates a problem in the lans assembly.
The most likely cause for this is a zoom or focus lens out of place or impaired in some way. This will require disassembling the camera to remove the lens assembly and then disassembling the lens block to repair. This can be done fairly inexpensively but it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
I cant transfer my videos
Hi
Just Try This
if you want transfer my videos from CAM to PC then you have to Finalize the disk first of all fallow this setup
Connect the AC
Adaptor to the digital video camera.
- Plug the AC adapter into a working wall outlet.
- Turn on the digital video camera.
- Press the SETUP button.
- Press the UP ARROW or DOWN ARROW button
to select DISC SET.
- Press the ENTER button.
to select FINALIZE.
- If still images are recorded on the disc, press the UP
ARROW or DOWN ARROW button to select PHOTO MOVIE CREATE.
to select EXECUTE.
to select YES.
When the finalizing completion message appears,
press the SETUP button
Cannot locate manual. When
You can download the manual (and more) from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRDVD610
Lcd touch screen is not
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body or a defective LCD / touch screen module and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Camcorder fell. The disk was
i hope you havent knocked the lazer out of line????a hard knock will do that,,,,whats on the disk can be recoverd,,only?
Error message e61:10 on handycam dcr-dvd610
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sony DCR-DVD610 DVD Camcorder Lens cover is stuck
The lens cover mechanism is assembled and only accessable from inside the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
