20 Most Recent Sakar 38690 Camcorder Questions & Answers
0answers
Redtube mp4
Be the first to answer 1/10/2014 4:05:18 AM • Sakar 38690... • Posted on Jan 10, 2014Be the first to answer
Having trouble downloading videos to computer. Are there directions for use?
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
6/29/2010 2:37:37 AM • Sakar 38690... • Answered on Jun 29, 2010
0answers
Need user manual or instructions
Here is a link for the Driver and Manual for the Digital Concepts 3.1MP camera...
3.1 MP 57490:
Driver: http://downloads.sakarhelp.com/cameradrivers/57490.zip
Manual: http://downloads.sakarhelp.com/cameramanuals/57490.pdf
3/30/2010 1:46:18 PM • Sakar Video... • Answered on Mar 30, 2010
How do you get an LG LV720 video cassette recorder out of safe mode?
To get your LG LV720 video cassette recorder out of safe mode, you can follow these steps: Locate the original remote control that came with your VCR. Look for a button marked as C.LOCK or LOCK. Press this button. This should allow you to exit the safe mode3. If you don't have the original remote, you might face some difficulties. Some users have reported success by pressing the record button for 6 seconds on their Panasonic VCRs but it's unclear if this will work for an LG model.
4/21/2024 3:09:22 PM • Video Cameras • Answered 3 days ago
Movavi video editor 11
Hi, which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
3/17/2024 9:39:09 PM • Video Cameras • Answered on Mar 17, 2024
How to factory reset model sdr-b853009?
All question need 'make model (what it is) as first 3 words please. https://www.google.com/search?q=sdr-b853009+reset All answers can be found on Google. ..
3/12/2024 4:40:20 AM • Video Cameras • Answered on Mar 12, 2024
My foxelli trail camera is only doing black pictures at night?
I would check the IR lamps work on the front of the camera.
3/11/2024 7:23:24 PM • Video Cameras • Answered on Mar 11, 2024
What is error code EO1
Depends on what type of camera but this site may help you. https://www.instructables.com/Fix-JVC-GR-DV800U-Camcorder-Error-Messages-E01-E02/
3/11/2024 3:50:38 PM • Video Cameras • Answered on Mar 11, 2024
2answers
I am looking for an Instruction manual for Zennox 4000 camcorder please
https://files.canon-europe.com/files/soft29721/Manual/MV550i_530i_En.pdf
2/21/2024 2:12:51 AM • Video Cameras • Answered on Feb 21, 2024
Wilderness Innovations trail cam model number K8B37D. Owner's Manual please?
That particular model doesn't seem to be listed anywhere. Contact the maker direct. https://www.google.com/search?q=Wilderness+Innovations+trail+cam+K8B37D+manual ..
2/5/2024 8:50:23 PM • Video Cameras • Answered on Feb 05, 2024
Rca vhs camcorder cpr300 won't playback or record
This may be bad belts, and what you should check for is the belts on the side of the tape deck toward the lens and pickup(front), and the drive belt in the middle. All the belts are under the circuit board, so you need to remove that to get at them, and then you can replace them with rubber bands of same or slightly smaller size. Use a screwdriver to help get the old belts off, and put new ones on. (In the tight space) Then check if the tape deck opens and closes, and see if the tape moves when you hit play/record. If you put in a tape you know has a video written onto it, then put that in, and try to play it. If you get a noisy or staticky picture, then try wiping the video head drum(Big shiny cylinder that spins, with the small slits in the side.) with some alchohol and a glasses cleaning cloth or paper. Also, wipe the audio/control head, the silver box that the tape runs across just before it goes by the black roller. Also, check for gunk or obstructions that have gotten in the mechanism of the tape deck in the back. Make sure the video drum is spinning, and that the tape is pulled out of the cassette by some small rollers and wrapped around the video drum DURING playback/record. I say 'during' because some camcorders will retract the tape back to the cassette for fast forward and fast rewind. I hope you get your camcorder to work! Thanks! 73 Sincerely, Beauregard42. (<-- My YT channel where I have some tech stuff)
1/9/2024 12:49:45 AM • Video Cameras • Answered on Jan 09, 2024
2answers
Error occurred please turn unit off then turn on again
Then what happened ?
1/2/2024 9:13:47 AM • Video Cameras • Answered on Jan 02, 2024
2answers
Silicon Valley Products SVP HDDV 2600 video camera. How to download drivers for it please?
There is no software online, it was a 'one hit wonder' and it says the disc that came with it only contained drivers and Ulead Video Studio 7, Ulead Photo Express 5. Fairly typical on such devices. Everything for $100 including the disc. https://www.ebay.ca/itm/275425639098 https://www.manualslib.com/manual/315830/Svp-Hddv-2100.html Driver Guide says it has them. Or you can connect the the camera to the computer, turn it on, then go to Device Manage in Settings and you will see a device with a banged out triangle icon,. Right click and click Find Driver. Microsoft should have one that works. https://www.google.com/search?q=svp+hddv+2600+video+camera+drivers+download ..
12/30/2023 3:11:37 AM • Video Cameras • Answered on Dec 30, 2023
3answers
Problem with Panasonic Camcorder NV-DS28
From speaking to a repair centre this is a very common problem with Panasonic camcorders.
I got the impression it was a panasonic problem with a connector that needed either cleaning or replacing.
There are 2 fixes, one is cheap quick and temporary.
The other involves sending the camcorder away to be professionally repaired, it should cost the minimum fee, which was £50 in 2007.
As for the cheap version, it involved turning the camcorder off and hitting it against a copy of the yellow pages and turning on again.  This worked for long enough to record my 2nd daughters birth.
12/13/2023 6:36:05 AM • Video Cameras • Answered on Dec 13, 2023
Sakar 38690 Camcorder Logo
4 questions posted
Top Sakar Video Cameras Experts
 Mikey
Mikey
Stan Ford
Are you a Sakar Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Sakar Video Cameras
  • Sakar Video Cameras
Most Popular Question
having trouble downloading videos
  • Video Cameras
