20 Most Recent Sakar 32492 Camcorder Questions & Answers
Will not work when i put in a memory card
Hi, I hope you can follow this. Remove the storage card from the computer, then go to control panel
then
device manager
expand portable devices
the type of memory card slots should be listed if your type has a yellow triangle by it,
right click on it and choose uninstall.
It should the reinstall automatically or when you put the storage card into the slot.
this type of fault is quite often caused by not using the safely remove hardware application on the taskbar....
THANKS.
4/11/2011 7:44:49 PM • Sakar 32492... • Answered on Apr 11, 2011
No audio
you may have acidently changed the setting, mess around abit and I'm sure you'll find it :)
4/19/2010 3:31:56 PM • Sakar 32492... • Answered on Apr 19, 2010
What is the largest size SD card that I can use?
If you bought before 2007 you need to stay smaller than four gigs. If you bought afterwards you can stick anything you want.
11/21/2009 4:45:53 AM • Sakar 32492... • Answered on Nov 21, 2009
0answers
Need user manual or instructions
Here is a link for the Driver and Manual for the Digital Concepts 3.1MP camera...
3.1 MP 57490:
Driver: http://downloads.sakarhelp.com/cameradrivers/57490.zip
Manual: http://downloads.sakarhelp.com/cameramanuals/57490.pdf
3/30/2010 1:46:18 PM • Sakar Video... • Answered on Mar 30, 2010
Movavi video editor 11
Hi, which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
3/17/2024 9:39:09 PM • Video Cameras • Answered on Mar 17, 2024
How to factory reset model sdr-b853009?
All question need 'make model (what it is) as first 3 words please. https://www.google.com/search?q=sdr-b853009+reset All answers can be found on Google. ..
3/12/2024 4:40:20 AM • Video Cameras • Answered on Mar 12, 2024
My foxelli trail camera is only doing black pictures at night?
I would check the IR lamps work on the front of the camera.
3/11/2024 7:23:24 PM • Video Cameras • Answered on Mar 11, 2024
What is error code EO1
Depends on what type of camera but this site may help you. https://www.instructables.com/Fix-JVC-GR-DV800U-Camcorder-Error-Messages-E01-E02/
3/11/2024 3:50:38 PM • Video Cameras • Answered on Mar 11, 2024
2answers
I am looking for an Instruction manual for Zennox 4000 camcorder please
https://files.canon-europe.com/files/soft29721/Manual/MV550i_530i_En.pdf
2/21/2024 2:12:51 AM • Video Cameras • Answered on Feb 21, 2024
Wilderness Innovations trail cam model number K8B37D. Owner's Manual please?
That particular model doesn't seem to be listed anywhere. Contact the maker direct. https://www.google.com/search?q=Wilderness+Innovations+trail+cam+K8B37D+manual ..
2/5/2024 8:50:23 PM • Video Cameras • Answered on Feb 05, 2024
Rca vhs camcorder cpr300 won't playback or record
This may be bad belts, and what you should check for is the belts on the side of the tape deck toward the lens and pickup(front), and the drive belt in the middle. All the belts are under the circuit board, so you need to remove that to get at them, and then you can replace them with rubber bands of same or slightly smaller size. Use a screwdriver to help get the old belts off, and put new ones on. (In the tight space) Then check if the tape deck opens and closes, and see if the tape moves when you hit play/record. If you put in a tape you know has a video written onto it, then put that in, and try to play it. If you get a noisy or staticky picture, then try wiping the video head drum(Big shiny cylinder that spins, with the small slits in the side.) with some alchohol and a glasses cleaning cloth or paper. Also, wipe the audio/control head, the silver box that the tape runs across just before it goes by the black roller. Also, check for gunk or obstructions that have gotten in the mechanism of the tape deck in the back. Make sure the video drum is spinning, and that the tape is pulled out of the cassette by some small rollers and wrapped around the video drum DURING playback/record. I say 'during' because some camcorders will retract the tape back to the cassette for fast forward and fast rewind. I hope you get your camcorder to work! Thanks! 73 Sincerely, Beauregard42. (<-- My YT channel where I have some tech stuff)
1/9/2024 12:49:45 AM • Video Cameras • Answered on Jan 09, 2024
2answers
Error occurred please turn unit off then turn on again
Then what happened ?
1/2/2024 9:13:47 AM • Video Cameras • Answered on Jan 02, 2024
2answers
Silicon Valley Products SVP HDDV 2600 video camera. How to download drivers for it please?
There is no software online, it was a 'one hit wonder' and it says the disc that came with it only contained drivers and Ulead Video Studio 7, Ulead Photo Express 5. Fairly typical on such devices. Everything for $100 including the disc. https://www.ebay.ca/itm/275425639098 https://www.manualslib.com/manual/315830/Svp-Hddv-2100.html Driver Guide says it has them. Or you can connect the the camera to the computer, turn it on, then go to Device Manage in Settings and you will see a device with a banged out triangle icon,. Right click and click Find Driver. Microsoft should have one that works. https://www.google.com/search?q=svp+hddv+2600+video+camera+drivers+download ..
12/30/2023 3:11:37 AM • Video Cameras • Answered on Dec 30, 2023
Sakar 32492 Camcorder Logo
5 questions posted
Top Sakar Video Cameras Experts
 Mikey
Mikey
Stan Ford
Are you a Sakar Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Sakar Video Cameras
  • Sakar Video Cameras
Most Popular Question
will not work when put in memory card
  • Video Cameras
