Hi my name is Roety,
I can help you with your issue ,
Even before you run the auto program you should see a picture when entering a channel below 13 when entering the numbers in the remote. If no picture shows check the signal source the center connector may be bent.
Another possibility is selecting ant 1 or 2 make sure you are selecting the correct input the check the picture then run auto program
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks I’m happy to help further over the phone at
https://www.6ya.com/expert/eric_ab7c09ec01841771
