20 Most Recent
ASUS Eee PC 901 XP Notebook Questions & Answers
How do i reset a eee pc 901
To reset my 901 XP, I remove the battery as shown on page 3-3 of the instruction manual.
The reset button can now be accessed: it is a small shiny metal
plate, about 3mm by 15 mm located on the left of the battery compartment (closest to the LAN port).
Press the metal plate once with a ballpoint.
Reset power button
Not behind the battery.
In the middle panel on the bottom in a tiny hole.
Use a paper clip to push it, hold fo10 seconds.
How to reset my Eee
Read through the instructions here http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&p=20&m=Eee%20PC%20901/XP&s=1&hashedid=1sRO7tW9B0OdR9yz&os=&no=1718
It tells you how to do a system restore on your netbook.
Thanks
How to Free up low disc space on asus 901?
Open Disk Cleanup by clicking the Start button. In the search box, type Disk Cleanup, and then, in the list of results, click Disk Cleanup.
In the Drives list, click the hard disk drive that you want to clean up, and then click OK.
In the Disk Cleanup dialog box, on the Disk Cleanup tab, select the check boxes for the file types that you want to delete, and then clickOK.
In the message that appears, click Delete files.
Can i do system recovery
Generally, most "System Recovery" processes involve re-imaging the system from a stored backup image of the system. This process normally overwrites the entire HDD including your data. So before running a recovery, I'd backup anything important.
My eee pc 901 doesn't
Hi
It seems to be there is pressed button and should be released.
Try with the control keys like ( Ctrl, Alt, Shift, both right and left, and Fn key ).
Press these keys hardly ( not much ) to release them,
Please, Tell us your results.
Good Luck
My wireless is tuned
As if the wireless of ASUS notebook computer has two switch.You enable it in windows device manager.It is the one switch of them.But maybe it doesn't work.The other switch is on you computer's pad,near the keyboard.If you didn't find it,I suggest that you use Intel wireless control program to control you WiFi.
My ASus eee pc is
Ok-Go to Safe Mode-any-click on start menu-run:msconfig-hit enter-click on restore option-choose date-go! If you can't do that, on boot you machine should tell you what other option you have-like"push ESC button to aces setup" or something like that. Hit that button and go to RESTORE function.Good luck and Happy Holidays!
On my daughters Asus Eee
It's possible that the disk-drive inside the computer has failed.
So, the copy of Windows stored on the disk-drive cannot be read, and Windows cannot start-up.
Take the computer to a qualified technician, for trouble-shooting (which may include replacing the disk-drive).
Is it still under warranty? (Was it purchased with a credit-card that automatically doubles the length of the warranty?)
