20 Most Recent
Gateway MT6730 Notebook PC Questions & Answers
How to disable SMART on Gateway MT6730
You can type in "msconfig" into the start window and when it opens then click on the "startup" tab at the top then look for the program you want to disable and uncheck its box on the left. If the program isn't there then try this: Type in "services" into the start window then click on services in the menu. When the services window opens look for the program you want to disable then right click on it then click on "properties" then click to open the options in the startup type window and choose "disable".
Memory upgrade 2gb 4gb ram
You can go online to 4allmemory.com and their site can tell you if it is possible by typing in your PC information.
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use. Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Cooling fan with heatsink on
presley2001 it is that easy!! On a lot of laptops it's as easy as removing a panel and a few screws...
Please, please, please, we need to know how we aredoing! Please rate our help to you and leave us a comment so we could go onhelping people like you that need our assistance and expertise! Thank you and,
Thankyou for using FIXYA!
Bestregards,
Junior
When i'm using skype or
did you configure the skype for voice calls
Check in Call menu in the option Aduio Settings that you have enable your microphone enabled and with the correct volume
Or make a call to the Echo / Sound Test Service to see if your micro is enabled
If you cannot hear you record you can got the Menu Help and select the option Call Quality Guide and select the apropiate option
Gateway Mt6730 starts up and then message comes up
Try cleaning the air vents too with a can of compressed air as dust can block these vents causing the CPU to overheat. The vents can be located at the back or sides of the laptop. Also a good idea is check and make sure that the CPU fan itself is working and spinning up.
Regards.
Internal microphone in gateway turned off, now will not turn on.
You may need to raise the level by going back into Control Panel -> Sound. From there, click the Recording tab -> right-click Microphone and select Properties. Finally, click the Levels tab and raise the level.
I had to do this on mine, too.
Hope this helps.
Gateway laptop will not power on
Sounds like to me, that you do have power going to your computer(other wise your lights wouldnt be on), but that your hard drive is dead.
You can take it to a computer shop and have them replace your hard drive.
Laptop comes on for a few seconds then nothing
Sounds like you may have an overheating issue with the processor. If it has gone on for some time, there could be damage to the processor and that is accounting for the short turn off time. If the system powers up on the battery alone, does it still shut off?, if you take the battery out and just attach the ac cord, does it shut off just as fast? If the unit has run hot for some time and not shut off there is a good chance it has dried the thermal grease on the processor or it has done irreperable damage to the processor itself and they may have to be replaced. First get some compressed air you would get at an office supply chain and using short bursts of compressed air, spray it in the vents, ducts, pull the cd tray out and blow air through the cd drive, open the bottom of the case and blow air in all the compartments. Blow air across the keyboard, but pay close attention to the heatsink, and it vent grills.
Internal microphone won't work
Open volume control.
When the box with all the sliders opens up click on OPTIONS (top left)
Click PROERTIES
Tick RECORDING then clck OK
The slider box will swap to the RECORDING slider box
Select the one you want to use as the recording SOURCE and put a tick in the box at the bottom.
You can also set the recording level here too.
Now click OPTIONS once again
Then PROPERTIES
Now tick PLAYBACK and then OK
You should now be back in the normal playback slider box
Whilst you were in the properties for either recordeing or playback you may have noticed a list of devices to show then as sliders tick them
