20 Most Recent
Dell desktop and monitor -Inspiron 530-Intel?® CoreTM2 Duo Processor E4600 Questions & Answers
I cant play music from pc desktops
strange questien.what's wrong ?CD-player? or what wish you had been moore exatly.can be many things.is all cords on the right place.?is the speakers okey.? information is importent.
My monitor is showing no input signal
Look to see if you have more then one input on the monitor, if the monitor is wired and only has the one you can't try another one. It's rare that the onboard video goes bad, usually the monitor die's before the onboard video. You didn't post what model to see if you have a card or onboard, knowing the CPU doesn't help. See if you can borrow a monitor from a friend, if it's not the monitor it's the PC.
Audio plays but no video
If you have catalyst control centre running go into the settings for basic video in it and make sure it's not set to custom
Arrow wont move
Dear Fayereid01,
You said "I have a dell computer and when I turn it on to the desktop the arrow wont move to go any further its a desktop with a IBM keyboard"
Make sure that the mouse is plugged into the the correct port. If the mouse you are using is a USB mouse then try other USB ports. If it is another type of mouse that uses a different plug, then try all the ports on your computer that it fits into until it works. It sounds unprofessional but it should work.
If none of this works then put in the CD that should of come with you mouse and install the drivers for your mouse. If you cant find the disc for your mouse then go online to the manufacturers website and you should be able to download the drivers there.
If i was helpful please rate me positively
It wont download
I not have sufficient input for your problem. But I assume you download the file thru browser.
If you are downloading from the browser saving the file and not selected where to save, look @ the temporary folder. Go to Start|Run| {type %temp%}. When Explorer opens, look for music files. Or do a Search on %temp% folder. If you want mp3 use 8.mp3, for jpg use *.jpg. For all use *.*
Restarts or reboots screen reads "diskett 0 drive failure"
1024 X 768 is the ideal setting for a 17" Monitor. Are you still getting sound output despite the error message? If no sound then your integrated sound card has failed, you will have to install anew one in the PCI Slot, otherwise forget about the warning & keep listening. You could try visiting the Official website to see if any driver updates have been released till date and refresh the drivers(sound) installation...............sodeep
PS: Check your Floppy drive? If not working simply disconnect and likewise in the BIOS if REQUIRED.
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
