20 Most Recent Sony Cyber-shot DSC-T70 Digital Camera Questions & Answers
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Sony Cyber-shot... | Answered on Nov 25, 2018
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
Sony Cyber-shot... | Answered on Nov 11, 2018
If it also does not turn on with power supply, then unit has died prematurely. A shame, no more warranty.
Sony Cyber-shot... | Answered on Apr 01, 2017
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Sony Cyber-shot... | Answered on Jan 16, 2017
It dates back to 2007
Sony Cyber-shot... | Answered on Jun 20, 2014
You may download the manual and more from http://esupport.sony.com/US/p/model-home.pl?mdl=DSLRA350&template_id=1&region_id=1&tab=manuals#/manualsTab
Sony Cyber-shot... | Answered on May 16, 2014
Use the scene setting mode to select a faster shutter speed, use either the high sensitivity or hi speed settings. See page 43 here
Sony Cyber-shot... | Answered on May 12, 2014
You may download the manual and more from http://esupport.sony.com/US/p/model-home.pl?mdl=DSCW710&template_id=1&region_id=1&tab=manuals#/manualsTab
Sony Cyber-shot... | Answered on Apr 16, 2014
If the camera came from Japan, there will be no english in the camera. If the camera had English before, you could try to switch the language back, by using the manual and count lines in the menus, to "feel" what part of the menu you are. (Setup menu)
Sony Cyber-shot... | Answered on Jan 18, 2014
Touch [HOME] to display the HOME screen, touch the toolbox icon, touch the camera-2 icon, then touch the "A" icon.
Sony Cyber-shot... | Answered on Dec 19, 2013
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
I assume you are looking for DSC-T70 owner's manual.
Click Sony Support to download free copy.
Sony Cyber-shot... | Answered on Dec 03, 2013
Yes the sounds when you are taking photos can be silenced.
Sony Cyber-shot... | Answered on Oct 15, 2013
My sony DSC-T70 is vibrating when open every time.
Sony Cyber-shot... | Answered on Aug 19, 2013
languej
Sony Cyber-shot... | Answered on Apr 15, 2013
Sony Cyber-shot DSC-T70 Digital Camera Logo
225 questions posted
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
 Larry
Larry
 MikeWang
MikeWang
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
screen vibrates intermittantly also
  • Cameras
