20 Most Recent Kodak EasyShare V1073 Digital Camera Questions & Answers
If you just recently purchased this camera, please contact or call the Kodak help line. You may have received a battery that won't charge. Batteries need a charge at least once a month to keep them at maximum preformance. Leaving the camera battery uncharged for long periods of time can cause the battery to fail sooner than it should. If you do need to set aside your camera for a long period of time, put a full charge to it and then remove it from the camera. Most cameras (video cameras included), even if they are turned off, can trickle the charge down on your battery.
http://www.kodak.com/global/en/service/contactKodak/kodakPhoneNumbers.jhtml
Kodak EasyShare... | Answered on Mar 22, 2018
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Kodak EasyShare... | Answered on Apr 04, 2015
The battery itself may be defective sometimes the factory sends out a bad unit. Call customer service from were your battery was purchased and inform them of your problem...
Kodak EasyShare... | Answered on Dec 13, 2014
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Kodak EasyShare... | Answered on Nov 20, 2014
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Kodak EasyShare... | Answered on Oct 05, 2014
There is no way you to mass deleted all pictures by just touching the screen. You must first display the pic you want to delete, then press the Trash Icon, then select yes on the screen, so accidental pic deleting is very hard to do.
I believe your pics are still on the camera, else the camera is defective.
Kodak EasyShare... | Answered on Jun 19, 2014
almost all easyshare (and Kodak cameras) eat batteries..... in my opinion, they're not worth the materials they're made from.
Kodak EasyShare... | Answered on May 25, 2014
"new camera"??...... take it back to the shop and buy something else (not Kodak..... and certainly not a "easyshare"..... so many problems and faults and Kodak won't help you..... notice i didn't use the word "support")
Try cleaning the contacts on the battery and camera.
Kodak EasyShare... | Answered on May 08, 2014
no u cant im pretty certain
Kodak EasyShare... | Answered on Sep 04, 2013
Kodak EasyShare... | Answered on May 30, 2013
Go to E-Bay and search your model.
Kodak EasyShare... | Answered on Jan 25, 2013
This is normally a censor error problem, requires service tech.
Kodak EasyShare... | Answered on Jan 24, 2013
Hello, Camera needs service/repair, Fault with touch-screen.
Make sure your batter is fully charged, and is not bad. This kind of reaction can happen with a weak battery or partly charged.
If that is not it, then the camera needs repair.
Kodak EasyShare... | Answered on Aug 27, 2011
Here's the page from the extended user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg00964/urg00964c3s2.shtml
Kodak EasyShare... | Answered on Jul 29, 2011
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional. Use these at own risk as it may further damage the camera. Firstly, try connecting your ac adapter or usb cable. Try holding the shutter button while switching on the camera.
Look at the lens, and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down). Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair (but as your camera has been dropped this will not apply). If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
You can also have a look at THIS link.
Hope helps.
Kodak EasyShare... | Answered on Jul 02, 2011
Kodak EasyShare V1073 Digital Camera Logo
129 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
daleted all photos
  • Cameras
