This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
I will say with 95% certainty the camera was dropped while the lens was extended. It does not take much of an impact to make the Canon lenses lock up, a very small drop, or even banging the lens into a door or something while it is extended will do this. It happened to my Canon, and two other friends' Canon cameras as well! Googling the issue also shows how common this is. I had my camera hanging around my neck and merely bumped my extended lens while opening a door. The gears inside are SO fine, and it skips just one tooth and it will fail. It sucks. Sending the camera in to Canon for repair seems to be the only option, since you already tried gently push/pull/twist of the lens while it tries to retract. That worked for one friend, I sent mine into Canon for $50 repair. Sorry.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
The battery door is seized, the impact has shifted the casing throwing it out of alignment preventing it from been opened, unless you can get it to release the camera will need to be disassembled in an attempt to release the mechanism.
The best way to download pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo/video cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Here's some examples on LCD replacement. The most common error that might cause the symptoms that you're experiencing is not fully seating the ribbon cable in its slot. It's usually good to use the tips of a tweezer, or a couple toothpicks, and place them in the tiny holes near the end of the ribbon cable to give a little more leverage into pushing the cable fully into its slot.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
You can download the manual (and more) from the manufacturer's web site at http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd890_is#BrochuresAndManuals
I would recommend you to buy Canon PowerShot SX210IS 14.1 MP Digital Camera with 14x Wide Angle Optical Image Stabilized Zoom and 3.0-Inch LCD.Decidedly slim and sleekly refined, the PowerShot SX210 IS packs a feature set that reads like a wish list. The 14.1 Megapixel CCD joins a 14x 28mm Wide-Angle Zoom for imaging power to spare. Frame your shots in the bright 3.0-inch widescreen PureColor System LCD, with the Low Light mode for sharp images in dimly-lit situations. It also captures stunning HD movies with Dynamic mode for enhanced image stabilization when shooting movies using wide-angle settings. Capture smooth HD video (720p) with stereo sound for a truly natural, high-quality HD experience. The PowerShot SX210 IS not only goes wherever you do, but takes your photography and video to a whole new place, too.
You can check out more detailed review for PowerShot SX210 IS
http://hubpages.com/hub/Canon-PowerShot-SX210IS-Digital-Camera
