20 Most Recent
Polaroid T831 Digital Camera Questions & Answers
Why are my pictures over exposed?
Hard to answer with such limited information on your settings and what you're shooting but often it's because the camera settings are on Manual and not Auto. It could also be a setting in one of the other exposure options in your camera.
What kind of memory card do I use
You may use any SD card up to 2GB in size (4GB if you can find any). Make sure you get an SD card and not an SDHC card, as the latter are electronically incompatible and will not work. The brand and speed won't make much difference, though a faster card may download faster to your computer if you use a compatible card reader. I'd also stick with the major brands, such as SanDisk, PNY, and Lexar.
I used to always upload
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Plug in polaroid t831 to pc and pc doesn't recogni...
Picasa.
I need to download my Polaroid t831 driver
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
I need the settings for my camera to get perfect
The settings depend on what you want the picture to say to the viewer. The best settings for a landscape picture won't be the best settings for a portrait, for example.Your local library should have some books on introductory photography. They will explain what the different settings do, and when you might want certain settings for certain types of photographs.
I am needing help downloading my pictures on to a website for a picture book
Picasa.
Can't upload pictures. restarts computer
Picasa or any other photo cataloging program.
Polaroid t831 makes laptop blue screen!
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Polaroid t831 Blue Screen of
Picasa.
How to download from a poloriod to computer
Picasa.
My computer has windows 7.the camera works with xp.how can i make it compatible?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
