20 Most Recent
HP Photosmart D5360 InkJet Printer Questions & Answers
CD/DVD Tray open; Close Tray to print
This solution is taken from the HP website.
Follow these steps to print on a CD or DVD.
Make sure that the CD/DVD tray is completely closed (completely inserted into the product).
NOTE:
Make sure that the side of the tray that holds the CD/DVD is inserted into the printer first.
In HP Photosmart Essential, click the
Print
tab.
Click
Printer Settings
and then click
Advanced
to open the printer properties.
In the properties, click the
Features
tab.
In
Paper Type
, select
Printable CD 120mm
In
Source
, select the
CD/DVD tray
Save the settings and then again attempt to print on the CD or DVD.
Paper jam cleared no tears message still appearing
When you turn off the printer unplug it from power and the computer for a few minutes. Plug only the power back in and turn it on. Also consult the manual to find out how to "reset" your printer.
Hope this helps
My hp d5360 printer is
You should try to verify if the cartridge is correctly put on the bay. If this not work you can try to clean the metal plates with a sheet of white paper and alcohol.
Cartridge is full but fades
it could be that you did not use your printer for a longer period of time, the cartridge may be dry. Nevertheless, you can put one drop of some alcohol on the ink head. For this, you have to unmount it and take it out of the printer. Then wipe the head.
If you do not want to peform the first step, then look if there is a Cleaning or Deep Cleaning function in the HP printing software.
I need drivers for windos 7
Hi
You can get the drivers from HERE.
As you haven't provided the bit so you need to select the OS and then only you able to download.
All the best.
With Regards:-
Subhankar Ghosh
Printing envelopes
Hi ,
I dont no what operating system is installed in your computer so i am pasting a link that will show you how you can print envelopes in xp and vista operating systems....
XP:http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01449380&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=3194503
VISTA:http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01471845&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=3194503
ALL THE BEST
I am message is print cartridge not detected printer not working
Hello.
Lift the cover from your right while being in front of the printer. Leave it powered on.
You are going to see the cartridges coming in the middle. Here you can remove your cartridges by pressing on top & pulling it at the same time. To replace, just reverse the steps.
I hope that this helps you.
Please send your feedback & vote to help us help you!
