20 Most Recent
Lexmark X4530 InkJet Printer Questions & Answers
I need OCR folder for lexmark x4530
You can download and install the Lexmark OCR scan software using the installation disc that came with your printer only. The software is not available for downloading online.If you lost the disc, please contact Lexmark Technical Support Center to request for one. Thanks.
Lexmark only connects to print server
Make sure that you have the right SSID and password for your network. Also, try to powercycle your router and printer. Just unplug the power for about 30 seconds then plug it back in.If it still doesn't help, try to leave you network open without any password and check if the printer is able to connect. If it does, check if the wireless standard is set to b/g/n. If it is, set it to b/g.
Will not print but it will scan and copy
Some times printer manufacturer provide print and scanner drivers separately, did you try to find "print driver"?Or... some times when you plug your device prior to start installation agent, it do not work until... you re-connect your printer in to other USB port. Try it!
