20 Most Recent
Motorola Mobility MOTO U9 Pink Cellular Phone Questions & Answers
Hello. I live in Sarajevo.
Get Motorola original battery and charger.
For USB charging you need to install drivers. Not sure our drivers posted on our site currently provide support for this old model though.
Mark
Motorola Support
1/23/2015 5:56:00 AM •
Motorola...
Answered
on Jan 23, 2015
Need a new panel,charger and
you can buy it from the shop where you bought your mobile phone, or you can approach any mobile accessories store and change your panel , charger and also get it serviced.
thanks for rating
good luck
1/27/2011 5:55:37 PM •
Motorola...
Answered
on Jan 27, 2011
Brand new Motorola U9.
After powerup,
What this Err. means is an error code indicating that the new battery inthe phone is not compatible with your motorola phone capacity.
What you are to do to solve the phone problem is to take the phone to the store and the older battery that work with the phone from the start and make a replacement of it.
Note:make sure that the newly battery is as same as the older battery.
Thanks.
12/15/2010 9:32:42 AM •
Motorola...
Answered
on Dec 15, 2010
Changeing outer screen saver of motorolla u9
settings> options > edit > when you get to this part press the arrow to go to the right and it leaves you on a screen that you can change all of the image settings including the external screen saver. I hope that made sense
8/18/2010 1:38:37 PM •
Motorola...
Answered
on Aug 18, 2010
Not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
8/17/2010 4:26:23 PM •
Motorola...
Answered
on Aug 17, 2010
Motorola u9 charging problum
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And ifcharger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
8/6/2010 2:38:28 PM •
Motorola...
Answered
on Aug 06, 2010
