20 Most Recent Fostex Mr 8hd CD 8 Track Recorder with CDr Questions & Answers
3answers
My Fostex mr8 hdd "full"
If you can reformat the drive after dumping out anything you want saved MIGHT fix the problem...
The unit MAY not be able to tolerate fragmenting when you delete a snippet here and there... It may require large blocks of contiguous space.
5/13/2017 4:17:22 AM • Fostex Mr 8hd CD... • Answered on May 13, 2017
Why does my mixer take so long to select something from the menu and why does it freeze up?
Sounds like you need more ram or computer space. You didn't list what time of mixer or computer so can only answer basicly. If using a computer (which it sounds like) see how much the mixer needs andhow much space available on your hard drive. This is called a latency problem. Basicaly how long does it take for the computer to respond to commands while it is doing a task. either get a bigger hard drive and more ram or clear out some files on your computer. You can also go into settings and change the settings. You'll have to look through the manual on latency problems.
11/26/2014 2:00:16 PM • Fostex Mr 8hd CD... • Answered on Nov 26, 2014
My Fostex MR-8HD states "Illegal song name" when
On page 22 of your manual, it appears that the warning message is used for more than one thing.
Make sure that you have entered the new song name text and it is accepted since if the name is not entered and accepted you will get that message.
If the text is unacceptable OR you try to advance to song creation when name has not been accepted will bring up that message.
The manual is really poor and I can understand your frustration.
It is UNCLEAR to us exactly at what point in the entry the message appears. Have you entered all the song name using all letters and then selected the enter function below? Does the message appear before you select the enter? or after you do...?
8/25/2012 6:07:10 PM • Fostex Mr 8hd CD... • Answered on Aug 25, 2012
2answers
I recently bought a MR
Yes, if this was a used unit when you bought it, then the problem is it needs cleaning. if you do a cleaning, it will improve the sound and the volume. Get a CD cleaner.
6/10/2011 7:20:05 PM • Fostex Mr 8hd CD... • Answered on Jun 10, 2011
Where can I get a menu/enter knob for my MR-8HD?
Such a knob will be "special" so best to go to the manufacturer...
http://www.fullcompass.com/brand/FOS/Replacement-Service-Parts.html
2/13/2011 11:56:43 PM • Fostex Mr 8hd CD... • Answered on Feb 13, 2011
I need a manual for the mr8
1/22/2011 2:52:41 AM • Fostex Mr 8hd CD... • Answered on Jan 22, 2011
When you turn on it says please wait and freezes
Sounds like a HD (hard disk) failure to me. I would suggest contacting your supplier.
1/16/2011 3:15:40 AM • Fostex Mr 8hd CD... • Answered on Jan 16, 2011
Bought this from a friend
TRY E-BAY. OR GIOVANIA.
12/22/2010 9:57:20 PM • Fostex Mr 8hd CD... • Answered on Dec 22, 2010
My Fostex MR-8HD recorder's LCD display won't show
Check if the display has a contrast control. When these get turned down, the display is blank. Sometimes they are a littel shaft coming out of the case, other times it is a setting in a menu... how they expect you to see the display to set it in these cases is beyond me...
10/23/2010 6:51:16 AM • Fostex Mr 8hd CD... • Answered on Oct 23, 2010
Hello. It's my first time
You will need to put th set on for really some time. I assume that the person who gave you must give more information if the recorder was working prior to this or was idling for along time.
If so leave the set on and allow the electronics to bring up voltage to all stages.
If there is no result look near the display unit the links, the cconnectors and the processor.
Now is your experienced friend can check out the prrocessor and display interface we can have some leads.
So check this out and respond
9/19/2010 11:30:54 AM • Fostex Mr 8hd CD... • Answered on Sep 19, 2010
Maybe stupid question....is it possible to record
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
8/30/2010 2:33:24 PM • Fostex Mr 8hd CD... • Answered on Aug 30, 2010
I have an intermittent fault
If you bought this machine from the manufacturers itself then you should try and take it back to them to help you fix it. This could sometimes be software problem. Try contacting the manufacturers of this, they could help you out.
Best regards
8/8/2010 4:45:19 PM • Fostex Mr 8hd CD... • Answered on Aug 08, 2010
Obsolete instuction manual
  • http://static.fixya.com/Manuals/F/Fostex/Mr_8hd_CD_8_9560CD0193FD88FFF2BDF0CB4FC4A17E.pdf
or
  • http://www.fixya.com/support/p926153-fostex_mr_8hd_cd_8_track_recorder_with_c/manual-31688#
7/4/2010 6:23:19 AM • Fostex Mr 8hd CD... • Answered on Jul 04, 2010
Compact flash that i bought wont work
USUALLY the ultra and high density flash cards have trouble working in most music equipment.
Only buy the cards up to 2 Gb and verify compatibility with one of them before buying more.
5/9/2010 2:44:56 AM • Fostex Mr 8hd CD... • Answered on May 09, 2010
I have a Fostex VF08 and I need to find repairer in SE London
I'd recommend contacting W.D.Greenhill.com
4/3/2010 1:51:36 AM • Fostex Mr 8hd CD... • Answered on Apr 03, 2010
2answers
I have a Fostex MR8-HD that I have done alot of
Try storing your project on another media such as tape or a computer ( there is lots of freeware such as Audacity) and format your drive.
3/27/2010 11:32:00 PM • Fostex Mr 8hd CD... • Answered on Mar 27, 2010
Why does it say
Note that the name of the song CANNOT have blanks and the use of special characters is limited.
If you need a space in the name you have to use the underscore to creat a "space".
3/21/2010 2:27:54 AM • Fostex Mr 8hd CD... • Answered on Mar 21, 2010
Fostex Mr 8hd CD 8 Track Recorder with CDr Logo
Popular Tags
45 questions posted
Top Fostex Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fostex Music Expert? Answer questions, earn points and help others
View Most Popular
Fostex Music
  • Fostex Music
Most Popular Question
s first time
  • Music
