20 Most Recent Eagle Fisheasy 320c Fishfinder Questions & Answers
Repeated transponder issues with the lowrance 320c fishfinder
Reading the manual it does say that there is a temperature range for these. I"m not sure where you live but it might be cold enough that it is damaging the transducer in the off winter months.
6/1/2009 1:40:48 PM • Eagle Fisheasy... • Answered on Jun 01, 2009
I have acuda 128 &a cuda 168 and both stay on
I have the same problem.Cuda 168.There is no simulating mode in menu.What s the problem?
12/26/2023 5:44:53 PM • Eagle Boating • Answered on Dec 26, 2023
We need a charger for a Fastlane RC boat Sea Eagle #48709B 7.2v 1000mAH
Do you need a battery or a charger ... a battery is rated in mah and a charger is ma or amperes. 1000 ma is the same as 1 ampere.
5/4/2019 3:21:18 AM • Eagle Boating • Answered on May 04, 2019
My Eagle Fish Mark 640 failed to power up this season. Good voltage available.
See later answer.
5/5/2018 4:02:43 AM • Eagle Boating • Answered on May 05, 2018
Where would I send an Eagle Fish Mark 640 for repairs?
I am a bit reluctant to answer this question as it may sound like I am being rude, but here goes. Type the name into google. It will tell you this is a discontinued product, and will also tell you the nearest service place to contact which will probably be a Lowrance agent. Call them and ask if it can be repaired. If so send it to them with a note explaining what the problem is. If it cannot, throw it in the bin and buy a new one. Easy.
5/5/2018 3:52:30 AM • Eagle Boating • Answered on May 05, 2018
Wide view fish finder
may want to call or email the manufacture of the unit for that info
10/2/2017 6:36:59 PM • Eagle Boating • Answered on Oct 02, 2017
I have a eagle fish finder, it is a vg-250. i need a manual for this fish finder.
Hey Floyd, check this out:www.eaglenav.com › Downloads
6/21/2017 4:15:25 AM • Eagle Boating • Answered on Jun 21, 2017
Can I wire it together?
The impedance match most likely won't. I advice you not to attempt. Replace with matching Eagle model transducer.
1/11/2016 7:46:20 PM • Eagle Boating • Answered on Jan 11, 2016
I have a eagle fish easy 240 it won't power on
1.Check the online fuse on your unit and be sure it is still intact.
2.Look at the connector on the back of the unit and be sure there are no bent pins.
3. Check the battery voltage and verify it's reading 12 volts or more.
4. Check the voltage at the connector to be sure you are getting power to the unit.
5. If you've accomplished all of this and there is power to your unit and it still won't turn on then it's time to invest in a new unit.
7/7/2015 9:23:26 PM • Eagle Boating • Answered on Jul 07, 2015
Is this a g.p.s. also
Sorry Kurt This unit is a fishfinder only. If you require the owners manual, check the link below. -Steve http://www.eaglenav.ca/upload/Eagle/Documents/Manuals/uclassic.pdf
4/28/2015 12:56:12 AM • Eagle Boating • Answered on Apr 28, 2015
Just got an Eagle Fishmarkde pathfinder need help w/mounting transducer to motor at end of shaft. If that is possible?
Hi Mike The transducer (depending on which one you have) should be mounted to the hull of the boat. If a transom mount, at the back of the boat of course and if a through-hull or in-hull ducer in an area that provides good contact with the water at all times. You shouldn't mount the transducer on the motor. I was unable to find a reference anywhere to the Fishmark DE. -Steve
3/14/2015 11:51:21 AM • Eagle Boating • Answered on Mar 14, 2015
I have an Eagle Ultra Plus Fish Finder( SERIAL # KU-037-4801) that I purchased in 1989 from Bass Pro. The unit's front plastic seal go cracked somehow and now the finger touch screen selections( ON/OF
Hi I think your best bet here would be to contact the manufacturer directly on this one. (link below) The trouble is... is the unit worth putting $ into or would you be better off buying a newer model. You MIGHT get lucky and find a similar unit on ebay, but unless you're REAL handy with electronic repair I doubt if you would get any joy. Welcome to the world of disposable electronics -Steve Service Info
3/3/2015 2:19:04 PM • Eagle Boating • Answered on Mar 03, 2015
Need pinout for power connector on rear of Eagle Magna view plus.
www.eaglenav.com/Support
6/4/2014 1:58:52 AM • Eagle Boating • Answered on Jun 04, 2014
Eagle Fisheasy 320c Fishfinder Logo
12 questions posted
Top Eagle Boating Experts
ZJ Limited
ZJ Limited
jws1013
ADMIN Andrew
ADMIN Andrew
Are you an Eagle Boating Expert? Answer questions, earn points and help others
View Most Popular
Eagle Boating
  • Eagle Boating
Most Popular Question
repeated transponder issues lowrance
  • Boating
