20 Most Recent
ASUS P750 Smartphone Questions & Answers
I wanna change my language settings
Hello :Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.OR:you can find in the settings>>phone settings>>language.hope this helps.if you need, and you don't have copy of the manual, let me know
4/20/2013 11:06:27 AM •
ASUS P750...
Answered
on Apr 20, 2013
I want to change chinies to english language in my asus p750
9/16/2012 3:25:06 AM •
ASUS P750...
Answered
on Sep 16, 2012
I have Asus P750 phone,
You need to install Active-sync which come along when you purchased the pda, if you do not have one, you can download from the net. After that, connect your phone to pc and launch the Internet sharing from phone,
9/13/2010 7:59:05 AM •
ASUS P750...
Answered
on Sep 13, 2010
How to change language setting in ASUS P750
Tap 'Start > Settings' (it is represented by a gray gear in front of an yellow folder. It should be the second item, from the bottom to the top, the closest one to the question mark (which stands for Help). Tap the second tab (standing for 'System') and search for an icon representing the Earth (standing for 'Regional Settings'). Tap over it and choose the language that better suits your needs, in the dropdown menu. Tap OK to save and quit.
This procedure won't change the entire ROM to the language you want, of course, but will allow you to better understand what is going on with your device, from now on.
Hope you are able to sort your problems out.
Regards,
Carlos
7/23/2010 6:33:50 PM •
ASUS P750...
Answered
on Jul 23, 2010
Instructions to replace LCD Display For Asus P750
Absolutely no problem. I had done it already with succes. Open the phone, replace and you are done! You cand download "P750 maintence manual" from internet, just google it. But open the housing carefully with no force, it can crack easily.
10/15/2009 3:40:19 AM •
ASUS P750...
Answered
on Oct 15, 2009
Asus z100 smartphone how to reset
Hard reset asus z100
- Start by switching off your ASUS Zenfone 5 by using the Power key.
- Then press and hold the Volume Up + Power key at the same time for a few seconds.
- Release held keys when you see Android Logo on your screen.
- Afterwards press the Volume Down to select option "Recovery", and press Power button to confirm.
- Next, press the Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
- Select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
- In order to restart the phone select "reboot system now".
- Success! The hard reset is done!
How do i hard reset my asus Z00D Zenfone 2E? i forgot my password onto my phone
- hold down the Power key for a short while to turn off your phone.
- Afterewards press and hold Volume Up + Power button simultaneously for a few seconds
- You can release held keys as soon as Asus logo appears on the screen.
- Then press Volume Down to select option "Recovery", and press Power button to confirm.
- When the Andorid logo appears on the screnn hold down the Power key
- While still holding this key press the Volume Up button once.
- Press Volume Down to choose "wipe data/factory reset", and then push the Power key to confirm.
- To restart the phone, select "reboot system now".
How do I reset my Asus phone
Back up all necessary data on the internal memory.
If the handset is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu.
A hard reset restores the original factory settings and erases content, including downloaded ringtones, images, programs, and contacts stored in the internal memory. This feature allows for resetting of sound profiles, display settings, and phone or memory card settings.
To perform a hard reset using the hardware keys, follow these steps:
Save any open files, and back up all necessary data on the internal memory if the device is responsive and can synchronize files. See: Prepare for a master reset and back up data on Android
Turn off the phone.
Note: If the phone is unresponsive and does not turn off, remove the battery and then re-insert it.
Hold down the Volume Up, Volume Down, and Power keys simultaneously.
When the Samsung log appears, continue to hold the keys until the master reset menu appears.
Press the Volume Down key to select Delete all user data when the Android master reset menu appears.
Press the Power key to confirm your selection.
Press the Volume Down key to select Yes – delete all user data.
Press the Power key to select reboot system now.
