20 Most Recent
Directed Dei Valet 561r Remote Start/Keyless Entry Questions & Answers
2005escalade remote starter
did you install a "gm remote start bypass", like DEI model 556L?
if not it is the passlock that is not allowing the car to start.
Vehicle lost fire
the security system doesn't disable spark, it works by not letting the fuel pump run or not allowing the starter to work, but never does it affect spark or fire as you call it.
Bypass
What are you trying to figure out what to do?
I have an 1998 Chevrolet
Hi, when last did you move the car on the road? Might weaken the power of the battery of the car and will not make the car start on time,or will not start at all..
Also you will need to check the alternator that charging the battery of the car .If the alternator does not work fine, might also make the car not to start because the battery will be too low to power up the car..
The key starter too can make the car not to start sometimes and will start sometimes too. You will need to check those places in the car to know exactly what is really wrong with the car...
Make sure there is Gas in the car and Engine oil in the car ),
That will help.
