20 Most Recent Roland Mv8800 Production Studio Questions & Answers
0answers
0answers
0answers
I deleted everything off my
You can probably restore factory settings but anything you had recorded and NOT backed up is unrecoverable.
8/16/2011 11:59:43 PM • Roland Mv8800... • Answered on Aug 16, 2011
I DID'NT BACK UP MY
Welcome to Fixya!
You can download the patches of this device by clicking this link. Make sure that you have winzip program installed in your computer so that you can extract the file. The installation procedure is included in the file.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
5/11/2011 11:52:17 AM • Roland Mv8800... • Answered on May 11, 2011
How can i replace the
MPCStuff.com has a great video walk-through of how to take apart the MV8800 and replace the pads with new ones. Here is the link:
http://www.youtube.com/watch?v=jDYXNQoiq74
3/5/2011 11:32:05 PM • Roland Mv8800... • Answered on Mar 05, 2011
F4 button pressed in
Most of the Roland buttons on this type equipment use a small switch that is actuated by a plastic button that is HINGED from a plastic panel behind the faceplate or a part of it. These plastic hinges get broken when too much force is applied to the button... it is USUALLY fatal and requires replacement of the whole button faceplate... and they are expensive... contact Roland parts to inquire.
3/2/2011 11:14:29 PM • Roland Mv8800... • Answered on Mar 02, 2011
Computer wont recognize device
Install the software non the disc or from their website before you plug it in. Try googling drivers for it.
2/28/2011 8:55:55 PM • Roland Mv8800... • Answered on Feb 28, 2011
Trying to wright some tracks
I have a similar Yamaha that makes me re-record the 16 tracks of the song onto the stereo track (left and right) then save. See if under the record setting if it has an option to "record to stereo track" or something similar. Hope that helps.
12/20/2010 5:30:08 AM • Roland Mv8800... • Answered on Dec 20, 2010
I bought mv 8800. I
This is NOT likely to be a problem with the power source at all but more likely with some setup parameter. Search your manual for subjects like "quantize" and also sampling rates.
12/2/2010 1:05:56 AM • Roland Mv8800... • Answered on Dec 02, 2010
Mv8800
full up the volume control
7/4/2010 1:43:30 PM • Roland Mv8800... • Answered on Jul 04, 2010
Need assistance in getting details of part number for power mixer
This is just a guess and the purpose is for you to get the datasheet and compare connections and see if they make sense... I have to do this often myself when documentation is unavailable.
Look up the datasheet for LM3886 on google and compare the package, electrical connections, etc. to see if that might be what is used.
MANY audio amps at this power level use this chip for the 50 to 68 watt range. They cost about $4 from the right sources.
If this is not what is used, the amp is probably in the TDA series of 5 and 7 pin TO220 style packages.
Other methods for these amps may involve class D switching amps and those usually use MOSFET transistors, not IC's.
5/6/2010 4:44:34 PM • Roland Mv8800... • Answered on May 06, 2010
Roland mv 8800 every time i try to load a cd its reads disk not
you could try a cd lens cleaner to clean the lens in the unit.
5/6/2010 1:39:51 PM • Roland Mv8800... • Answered on May 06, 2010
Seperate tracks
They have to be recorded on SEPERATE tracks if you want to keep them seperate. It will be hard to do this live as if you mic acoustics you will still get some cross feed in the mics from the different percussions.
With an electronic drum set it may be even harder as they often only have a single mixed output.
The way the professionals would do this is to play the kick and record it on a track... and then play that track back and record the snare and hat each seperately on other tracks.
Once you have synced tracks of the parts, then you can mix anyway you want.
With electronic drums you COULD have two seperate modules to give you two seperate outputs, but that is a budget breaker.
4/20/2010 5:19:12 AM • Roland Mv8800... • Answered on Apr 20, 2010
How do I fix a disc error. I cannot find my
You might go look on the vsplanet.com website for help.
10/27/2009 1:42:02 AM • Roland Mv8800... • Answered on Oct 27, 2009
Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
2/7/2009 12:56:47 PM • Roland Mv8800... • Answered on Feb 07, 2009
Roland Mv8800 Production Studio Logo
27 questions posted
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
  • Music
