20 Most Recent Elite Sl 3000 Ul Sliding Gate Operator Questions & Answers
4answers
Elite Miracle One abruptly stops with no slow down
http://specs.chamberlain.com/pdfdocs/0150593.pdf
Above is your manual, this has much information. From what you describe, I would think "Sensor" or "Drive" for the sensor. IF there was a Short, I don't really think, it would actually go? What you need to do, is use the manual and perform the troubleshooting steps, and check all sensors switches, etc. If the windings are shorted, then accordingly the "Drive" too, well, that would most likely be destroyed.. if it is so, you will need to check that too.and replace it.
12/6/2022 2:01:26 PM • Elite Sl 3000 Ul... • Answered on Dec 06, 2022
2answers
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
12/6/2022 1:55:18 PM • Elite Sl 3000 Ul... • Answered on Dec 06, 2022
Centurion D5 Evo sliding Gate Motor. FRX light can't go off after replacing the power supply unit.
Question edited for clarity, 'mske model (what is is)'. Question moved from Computers to a Gate System category. https://www.6thsensesecurity.co.za/resource_docs/14_Centurion_D5_EVO_installation_manual.pdf Free Exit Light. Check sensors. https://www.google.com/search?q=centurion+d5+evo+Frx+light+on ..
8/8/2022 6:33:01 PM • Elite Sl 3000 Ul... • Answered on Aug 08, 2022
How to program a liftmaster remote to an eagle gate opener
I have a eg640 and my mother in law has the same eg640 for are gate
7/18/2021 4:56:35 AM • Elite Sl 3000 Ul... • Answered on Jul 18, 2021
Gate opens randomly in the afternoon without known
Disable the telephone control to isolate that much of the system. You should be able to just disconnect the telephone line into the unit. Do without for a day or so to find if it might be the telephone control. IF IT IS get the telephone company to log the origination of the calls. If it still does it without the telephone, change the codes as it is likely some other nearby person has the same system and his codes are the same as yours. The unit is saying it is getting a valid command... so it has to be coming from someplace. There is a chance one of the remotes in your vehicle is sending this. You might, although it is inconvenient, keep one of the vehicles at a time say several blocks away to see if problem stops. Moisture in the button could cause one of the remotes to be sending the commands.
3/8/2019 12:48:11 AM • Elite Sl 3000 Ul... • Answered on Mar 08, 2019
I have SL3000UL Series gate
That light flashing means a limit switch issue is present. Check the switch and all the wiring to that switch.
6/10/2017 4:31:37 PM • Elite Sl 3000 Ul... • Answered on Jun 10, 2017
0answers
3answers
I have al Elite 3000 sl sliding gate opener that is not shutting. When I disconnect the electric power, it closes the gate sometimes half way and it stops, sometimes it closes the gate after one hour
Follow the steps in the manual if you have a manual and if you don't have one I recommend that you get one.
4/2/2016 9:26:16 AM • Elite Sl 3000 Ul... • Answered on Apr 02, 2016
My Elite Sliding Opener is not closing. It hits the the end of the gate hard and retracts back?
The Limit nuts are out of adjustment. This can be caused by the chain jumping the sprocket, usually when something gets caught in the chain or it has not been adjusted. It can also be caused by a cracked limit nut. The limit switch and nuts are located at the top of the operator (under the cover) and has a lid held on by a single screw. Loosen the screw, and remove the lid. elite-sliding-opener-not-closing-hits-3i3gptxgjc4ofcs21h1ecra2-1-3.jpg Inside you will see two cogs on a threaded shaft with slots cut into them. These slots are there so the lever will keep the nut from spins and allow it travel down the shaft as the shaft turns. The limit nuts eventually contact the limit switch, stopping motor. Look closely at the sides of the nut to make sure there are no cracks allowing the limit nut to spread open and slip on the threaded shaft. You may have to clean them to see it. elite-sliding-opener-not-closing-hits-3i3gptxgjc4ofcs21h1ecra2-1-6.jpg If there is a crack, usually found between the brass nut and a slot, you will need to replace the limit nut. Go ahead and do both nuts at the same time as it is a challenging process and you will want to do it only once. If the nuts are not cracked, simply press the bar holding the nuts in place back with a screwdriver and spin the nut towards the limit switch until the gate stops about one to one and a half inches away from the post. The gate stopping point can vary even more than one and a half inches on slopes so if it starts happening again, give it even more space. elite-sliding-opener-not-closing-hits-3i3gptxgjc4ofcs21h1ecra2-1-10.jpg Finally, a new limit nut may look different than the old one. The old ones with the brass nut encased in plastic had more cracking issues than the new all plastic nut shown here. Good luck
11/8/2015 3:55:52 PM • Elite Sl 3000 Ul... • Answered on Nov 08, 2015
2answers
My SL3000UL will sometimes lock open. The timer
I have the same problem with my new expensive system. My installer does not know what the problem is after looking into it and calling the company.
11/8/2015 3:22:05 PM • Elite Sl 3000 Ul... • Answered on Nov 08, 2015
I replace the mothrboard on elite slidding gate but the batery loses power
Since you have a battery and it is a sliding gate, I will assume you have a Roboslide model by Elite. The battery has to be charged in order for the gate to work. The charging comes from a transformer or a solar panel. Check to make sure these have power coming out of them. Most gate operators use a transformer and if the two wires providing the voltage touch each other, it will blow the transformer. If you have a volt ohm meter you can check this. You might need to use the AC setting as well as the DC since some are 18 volt DC and others are 25 volt DC. You can do the same for a solar panel but only use the DC setting. If this is not your issue, then make sure it is your battery draining and not something binding in either the motor or the gate. Finally, it could be the motor going out. Simply hook the charged up battery directly to the motor to check it. It should respond strongly. Reverse the leads to make the motor go the other way. Good luck.
11/8/2015 12:24:12 AM • Elite Sl 3000 Ul... • Answered on Nov 08, 2015
Why does the temperature affect the gate closing sensors? battery new in May 2015.
55 degrees f is 12 degrees c which is getting close to freezing I would be checking any ground points and cable connections for corrosion, rust and anything that affects resistance check the operating temperature range of the capacitor for the motor as it may be affecting the capacitor ability to function At 11 years and cold it could be bearing problems and lubrication Also remember that batteries do not work well when very cold (battery failure in cars when the cold weather begins) Is the battery charger operational ,keeping the battery fully charged
10/27/2015 11:28:19 PM • Elite Sl 3000 Ul... • Answered on Oct 27, 2015
Elite Sl 3000 Ul Sliding Gate Operator Logo
132 questions posted
Top Elite Home Security Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Elite Home Security Expert? Answer questions, earn points and help others
View Most Popular
Elite Home Security
  • Elite Home Security
Most Popular Question
elite sliding opener not closing hits
  • Home Security
