20 Most Recent
Audiovox FM Modulator EA FMM100A Questions & Answers
How to get to the stock stereo wires of a bmw
as far as i can remember. the volume knob comes off. Then there is a screw underneath this that you undo. the face then comes off the stereo. And inside here there are two metal pins that you press sideways to remove whole radio. Hope this helps.
What are the input wires on a audiovox amp777
The Audiovox AMP777 is a 4-channel power amplifier, and the input wires will depend on the audio source you are using. Typically, the amplifier will have RCA input jacks for left and right channels, and you would use RCA cables to connect the audio source to the amplifier. Some amplifiers also have a high-level input option, which would allow you to connect speaker wires directly to the amplifier's input terminals. However, it's always best to consult the user manual or contact Audiovox support for specific wiring instructions for your amplifier model.
My cd runs but will not play the cd
Quite common problem. Repair it or replace your player if repair cost is too high. Personally, I stopped using CD players time ago: I use a mp3 player.
