20 Most Recent
Goldstar MA-1012 Microwave Oven Questions & Answers
Where is the fuse located
The fuse is generally located very near where the main power wires. It is most likely located inside so the lid must be safely removed and the unit must be unplugged. The power wire will run directly to the fuse in a block. Replace with the same size and type.
I need a replacement plate for a goldstar
I found your glass tray listed at repairclinic.com. The part number is 1194865. The price is about $35. If you have questions, or need further assistance, please post back and let me know. I hope this helps you.
What is the wattage for ER-4010
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
4/12/2020 10:09:45 PM •
Goldstar...
Answered
on Apr 12, 2020
