20 Most Recent HP Advanced Port Replicator 1.2 Questions & Answers
Download a copy from HP. off their web site or try this site,
http://uk.wow.com/search?s_pt=aolsem&s_it=aolsem&s_chn=78&q=hp%20user%20manuals
HP Advanced Port... | Answered on Oct 24, 2013
There are a series of HP or Compaq USB drivers (depending on your model) that need to be installed before the dc366b is fully recognized.
On my Compaq Presario 1500/Evo N1020v I have the following driver service packs installed, You may want to see if these will work with your laptop...
USB sys drivers & updates
sp23847
sp25498
sp31317
sp31834
Port Rep drivers
SP19198
sp34083
HP Advanced Port... | Answered on Feb 05, 2010
The overheating problem will cause the CPU to shutdown and it won't boot up again until it has cooled dowm.
The problem could be a faulty fan that has stopped spinning and or the fan and heatsink assembly is clogged with dust.
To fix the problem, remove and vacuum the dust from the fan and heatsink assembly, check the fan and if it does not spin freely, replace the fan.
HP Advanced Port... | Answered on Jul 27, 2009
Hold the shutdown button for 15 seconds (be sure to count slowly). If this still doesnt help and you ABSOUTELY need to solve this issue, then you can try to risk removing and reinstering the battery pack of your laptop.
I tsounds like your laptop overheated. it should return the normal once it is rebooted.
HP Advanced Port... | Answered on Jul 02, 2009
you need to ask HP, that, it's laptop right?
only they can undo that, (by design)
hp 15 is not the full model name:
example #1, the service tag is read first, then told what it is.
HP 15-bs031wm then go here and ask HP, what to do. notebooks
https://h30434.www3.hp.com/t5/Notebooks/ct-p/Notebook
HP Computers &... | Answered Yesterday
AIO PCs seem to love to die,
the PC
so PC is silent, means lost of power, check AC cable, make sure to use wall jack AC not a power strip.
AIO are not easy to fix, most parts in side are non standard
so that makes them a pain.
why not get shop to fix it.?
did you hold the power button in for 5 full seconds as page 2 in your service manual directs.?
repeat that 2 times, 1st to end buggy sleep drivers, 2nd to hard power it on,
if that fails the , PSU bad top cause. (silent PC)
HP Computers &... | Answered 2 days ago
lots of words and means just Dead PC. fans spin.
HP model number HP touchsmart. (no model stated at all)
its dead PC and screen is dead.
most PCs from HP have external display port.
of some kind, Display port or others, the manual covers this but your PC model was not told nor service tag model. told.
The PC is dead, and seems the power button is bad too.
here are some steps used on all laptops
1: remove the huge battery in the lap top, do not make excuses how hard it is to unplug , you bought it so do what must be done,
2: use the AC power pack only, (unpugged for 1hour first)
then plug it in, this pack
3: the PC must not self turn on. so push the power button now see it manually turns on.
4 the BIOS HP logo page shows and BIOS screens work like ESC, F10, F11,
5: if screen is still dead, use the external monitor port and
the Fn+F4 button as the manual tells you to do.
no PC stated at all not even class of PC, desk or laptop. and no parts are free.
the TOUCHSMART word does not tell what you own
that name used back to 2007, 13 years long.
IS THIS AND AIO all in one PC,?
does it have a power pack that in in the line cord
is it the right pack for the AIO>?
AIO PCs only have a few parts inside that are standard, RAM and HDD, all else is HP custom, making them as hard to repair as laptops, lacking those parts custom.
first learn to identify a PC first then tinker.
see examples below.
HP Computers &... | Answered on Dec 08, 2019
no PC stated, 6122 if not a pc?. Pavilion (1 "L")
a desktop , laptop or printer, by that name yes
IDK what you have.
P6122 is desktop, is it? i will guess yes P6122.
no photos posted of PC nor all connections.
so working blind all I can do is ask questions
the cure is get it repaired in a shop. end story.
if you have tools and skills (do you?) then I ask this.
1: is the PC silent (y/n)
2: does the fan inside spin, (ever clean out the dust inside (normal service that)
3: does the CD tray eject,? using its button nearby?
if all above fail that is now power failure.
4: Is the screen dead? y/n, any text or logo splash screens are , no it is not dead screened.
I will assume PC is deas
5; does the PC beep or blink LED or show errors on the screen. and screen cable is plugged in to the VGA port or GPU card if present.
6: this PC is 10 years old and the RTC coin cell battery is now dead this old. replace it for $1
then set boot order to HDD0 first , hard disk #0
7: run HDD test next, I will stop here, as Im sure you are lost, (yes computers are complex)
show your service tag data.
for 10x better help
like this.
https://www.pcdied.com/raw/tag1.JPG
HP Computers &... | Answered on Dec 02, 2019
ilioSystemService is part of system mechanic program if its missing opr corrupted try reinstalling the system mechanic.if it wont fix the problem. contact http://www.iolo.com/customercare/technicalsupport.aspx to help you sort out that problem file. thanks
download and install codec for windows media player to play dvd movies from http://www.free-codecs.com/download/K_lite_codec_pack.htm
or download vlc player that play dvd directly from
http://www.filehippo.com/download_vlc/
HP Computers &... | Answered on Nov 30, 2019
your web connection is too slow.
non stated by you, let me guess wifi?
do internet speed test yet, goggle that, bingo.
no location stated., home, or starbucks or?
do other PCs, work , in same place? hummmmmm
windows 8.1 that? what do you mean.by 8.1
no pavilion PC model stated., not even desktop or laptop.
this is 2009 cam, and runs XP/vista/w7 software only.
lost the CD that came with it?
the maker is Vivitar, only they can source software.
id read this first.
https://www.lifewire.com/vivitar-support-2625707
i have working and fully max upgraded xw4600 , sister to yours.
MBR is limited to 2GB,(approx)
the OS must be 64bit, to go GPT,
are you saying to boot from this drive, full system not told
I run SSD as boot drive, 128GB. then drive 2 non boot can be any thing I want in w10 64bit, nobody uses w7, now, it dies, Q1, 2020.
UEFI safe boot needs, OS RELOADED, and to GPT.
and 64bit OS, it is NOT a BIOS issue. but do upgrade BIOS,
UEFI does not own GPT, you can run legacy with GPT, microsoft.com has full pages telling you how to do that.
I have w10 64bit, v1903 on mine. now. runs like champ.
once booted the OS runs the HDD not BIOS, a fact.
when you fresh load w10 64 from ISO the OS installer will set that 3TB as GPT , regardless of BIOS.
try it see.
but SSD drive there booting is always best. even on all my servers.HP and DELL.
you can set up w10 to put all data on drive, E: 3TB
or have 2 partitions there, programfiles and DATA.
then OS owns the SSD, alone.
hope that helps some.
HP Computers &... | Answered on Nov 28, 2019
HP Pavilion Slimline s5000 (s5100z)
fans spin, ok,
DVD tray enjects.
does this PC have the optional
the first 5000 was made in year 2003
then laters for VISTA.
id have to see your service tag info to wax smarter.
hp forum can help try that? hp.com
I guess the VGA port is dead, ?
most old PC had 2 ports, 1 on the card, one on the main chassis rear . if the card GPU vga is present only it works.
if you remove the GPU the main VGA port is live.
I cant see rear of your PC and seeing MATTERS.
the common failures are:
RTC coin cell dead.
HDD bad, (most are this old)
and PSU bad.
in that order.
You don't have the codecs needed to watch the movie.
Download some codec pack, or just use VLC.
Link to VLC
HP Computers &... | Answered on Nov 20, 2019
Tip
Why is Hp Printer Showing Offline on Windows 7
Folks are you afraid about your hp printer is offline status. In any case, this isn't added agilely to get the breach why is hp printer offline issue. Old you annex to analysis your availability on your hp printer. In the accident that you access captured your hp printer settings and ache isn't abiding so on the off adventitious that you accretion to administrate advance intends to get hp printer offline on windows 10 to on the web. That we proclaimed below for this hp printer is a broken issue.
on Nov 13, 2019 | Computers & Internet
As the computer is powering on;
Pressing the F11 key repeatedly,, click Troubleshoot, and then selecting HP Recovery Manager
HP Computers &... | Answered on Nov 13, 2019
Access google and enter, "how to restore HP laptop to factory defaults". Be mindful of the data copy/backup steps as this is important.
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
HP Advanced Port Replicator 1.2  Logo
4 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
driver software
  • Computers & Internet
