20 Most Recent
Dell XPS M1530 Notebook Questions & Answers
How to fix errors on hard drive
Your OS will run check disk on any of the drives in computer
If it does not then your OS is in need of repair. Install the drive as a secondary in another computer and run checkdisk with repair option. Takes time and if large drive , long time. It will locate any bad sector and cross it out so it does not get reused - will retrieve any data in the sector and put it in another good sector PROVIDED data can be read..If not readable you will lose that data but at end of procedure disk can be used. Remember that repair is temporary and once sectors start going bad more will follow later so it is prudent to start making plans, like backups and getting new drive.
How do I boot to windows or disable bitlocker?
Anonymous,
Steps to Turn On/Off BitLocker:
Click the Start button to view the Start Menu and then choose the Control Panel option.
The Control Panel window opens up.
Now click the System and Security link from this window.
The System and Security section of Control Panel opens up and you can see the direct link for the BitLocker Drive Encryption.
Click on the BitLocker Drive Encryption and a new window opens up.
By default the BitLocker Drive Encryption is Off for the Hard Disk Drive. Click Turn On BitLocker. If a compatible Trusted Platform Module.
Note: To use BitLocker Drive Encryption, your computer has to meet certain hardware requirements.
Otherwise, this opens the BitLocker setup wizard. Follow the instructions in the wizard. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Off BitLocker. This opens the BitLocker Drive Encryption dialog box. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dell XPS M1530 won't recognize external monitor
The XPS1530 uses Vista so go to the control panel and choose the port that you have the external monitor connected to. I use an HDMI cable and need to choose both the audio and video separately in the control panel.
Can't eject dvd from dell xps 27
I had this problem, talked to a Dell support person for two hours with no success. Went to bed, next morning, I powered the desktop off (not restart) with the power button. The first time, the DVD drive cranked up but didn't eject the disk. The second time I powered it off and then on again, the DVD drive ejected the disk.
Bios password reset on a
I am not going to take credit for information but here the link. Please read, removing the CMOS battery will never solve it nor replacing it.
http://www.fixya.com/support/r4342847-laptop_cmos_hard_drive_passwords_whole
Bios password remove?
You can try and pull the CMOS battery, but that will require taking the laptop apart. It's not something I recommend the average user try if they are not comfortable with computers.
Bios password
Wrong placeRepost in correct areaThis is automotive questions
Beep sound
If you recently upgraded or opened or dropped the laptop then something might have gotten loose. This has happened to me when my ram was not properly inserted.
How do I switch on my Dell XPS M1530, black screen
Here is a link to the owner's manual of your laptop which contains info on troubleshooting problems: ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1530_owner%27s%20manual_en-us.pdfHere is a link for the service manual of your laptop: ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1530_service%20manual_en-us.pdfHope this helps.
BIOS got the computer completelly blocked and I fo...
For Dell
Hello Sir I can help you .Send me service tag which u can see on the bottom cover or turn on laptop u will see on screen hash code like this XXXXXXX-595B or D35B, A95B or 2A7B send me complete .i will send You MASTER PASSWORD Thanks.
