20 Most Recent
ASUS Eee PC 900 PC Notebook Questions & Answers
Before, I can send and receive files using the
Hello Mylenejavier, To Send and Receive file using Bluetooth requires the following considerations:Make sure your Bluetooth drivers and adapters for your Notebook are up to date.Make sure the device driver of your phone is installed in your Notebook.Make sure that the Bluetooth function on your Notebook is switched on properly.If these steps are not work for you, dial my toll-free number +1 (833) 493-0111 . I'll Surely help you.Cheers,John
Issue with VOIP CAlling
well if the headphone doesnt work the person on the othetr line cant hear you try anothr headphone and see if it works also see if it compatible cause it might be eathr or
Asus computer password reset.
To unlock a forgotten Windows password on Asus, there are several free methods:1. With another admin account.2. With Windows password reset disk.3. From Safe Mode.4. With CMD.5. Using "lusrmgr.msc"More details you can found on other sites, it is easy to find.Another tip: Unlock forgotten Windows password with
Windows Password Recovery Tool.1. Install this program on another computer and create a password recovery disk with USB2. Insert the disk to your laptop and set your laptop to boot from it.3. All user accounts will be loaded, then you can reset any user password.
Forgot my email password and cant delete account
Which email account ? Hotmail have a forgotten password link but you must have another email adress to send your forgotten password to just open up another email acc at hotmail.com eg:
[email protected] in the right hand corner on the hotmail homepage you should see help center down in the bottom right hand corner tab click on that another page will open you should see another help center click on that again another page will open with account calendar contacts essentials Click on the account tab another page will open with if you have forgotten your password or are having trouble signing in yet another page will open get help with your password problem or signing in click on it you should see something like I forgot my password or I know my password but am having trouble signing in I think someone else is using my Hotmail account
at the sign in for your hotmail account click on forgot password tab another page will open then on the reset password tab Hope this helps.
Need to reinstall Windows XP on my Eee 900HA
Bill,If you havent just replaced your hard drive or formatted it, try restoring from the restore partition. I have a newer ASUS netbook, so yours i believe should restore by rebooting the laptop and repeatedly pressing the F9 key. Do not hold down the F9 key, just keep tapping it when it starts up.Follow prompts to restore your laptop to its original configuration when you first purchased it. Make sure to back up all your data, as it will be lost along with all programs and updates that have been installed since day 1.If you have replaced the laptop or formatted it, then youll need to either attach a USB CD/DVD ROM drive or use a USB Flash drive. That method is much more involved, but can be done as long as you have a copy of a Windows XP CD. I’m happy to assist further over the phone at
https://www.6ya.com/expert/larry_0800578514b4ccdb
I have an ASUS Eee PC 900. It was working fine
One more thing you could try is taking the battery out for a minute or two, because the Eee uses the atom it has a fairly complex onboard power controller that can overclock / underclock the cpu. Sometimes this gets malfunctions and locks the PC up, the quickest way to fix it is to simply pull the battery for a short while and stick it back in. You may well have already tried this, but it'll be the first port of call.
MISSING AUDIO DRIVER
google the serial model number of your sound card or get it from the asus support center
Asus pc Eee cant connect to the net
have you connect it with a network with your wireless? and does that connection connected succesfully?or are you using modem? does the modem connected succesfully?The url you try to go is valid,i've tried itcomment if you need more information
