20 Most Recent
Canon imageCLASS MF4690 Multifunction Laser Printer, Copier, Scanner & Fax, 21ppm, Maximum Size: 8.5 Questions & Answers
Imageclass mf4690 has streaks in copies
Several possibilities: if copying using the ADF - clean the glass under the ADF feed. If a print is the same as a copy - check the toner cartridge. This type of cartridge collects heaps of junk in the waste chamber which interferes with the print when nearly empty. If neither of those - dust on the imaging scanner = refer to service dude.
Canon MF4690 offline
double click on printer print queue opens make sure all print job is cancledthe click file and set printer online cabel must beconnected.Left click on printer and make sure you select the corect printer port or above will not work
I need to obtain a copy count report
You probably gotten the answer before someone answered your question if you went on to the cannon website and downloaded the manual. Below is the link.
http://usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4690#BrochuresAndManuals
New cartridge but copier not printing
Did you pull out the orange/red tape?
Check if there is an good connection between cartridge and pin at the right side of crg. inside crg.holder( a little pin wich goes in and out when you open or close cover )
Try with old crg. if it works the problem is new crg.
I need to reset the printer I just bought...it's a
- Unplug
the printer cable from the computer.
- Unistall the
printer drivers from Device manager and also unistall the all the printer
appications
- restart the
computer
- try to download
drivers from the website
- after installing
drivers and software it will ask you to connect the printer.
- then you can
connect the printer and and try to Print the test page.
Hope this help. Please
Rate My Response! Thanks!
Jammed paper
u have remove toner form the printer then u can remove by hand
I want to contact to canon xerox service centre kolkata
http://www.xerox.com/about-xerox/contact-us/enin.html
Contact Us - Xerox
Find a local Office Products dealer in your area: Kolkotta Office Xerox India Limited 37, Shakespeare Sarani, 1st Floor, Kolkata - 700 071. Sales: 033 - 44004875 ...
- Copiers like the Xerox personal copiers offer functionality that takes into consideration ... 8/1, Lalbazar Street, Room No.1 D ,1st Floor, Kolkata - 700 001, India.
http://www.copier.in/photocopiers/personal-copiers.html
