20 Most Recent
Logitech Driving Force GT Wheel for Playstation 2, PlayStation3 Questions & Answers
Why my brake pedal stays stuck until i pump it ?
My guess is there is a piece of plastic either on the pedal or the case that is rubbing. If pumping the pedal makes it work then the spring is probably okay. A small piece of plastic flashing from when the parts were molded may have dislodged and is causing the pedal to hang up. When you pump the pedal you are causing the small piece of plastic to bend out of the way. If you cycle the pedal enough the piece of plastic will likely break off. Sort of like breaking a soda can in half. If you bend it back and forth enough times it will eventually break.
Driving force gt broken ?
Check if you have configured the settings properly and also check if the device was installed correctly
Hi...I just bought the Logitech
-Check if the connections are plugged in properly
-Does the wheel calibrate (turn left and right and then centres) when you turn on the wheel.
-Doe the game support the wheel?
- Plug the DFGT into the USB port 1 of the console AFTER you turn on the console. So turn on the console and then plug in the DFGT into the USB port 1 and turn it on.
ALSO if you are using the DFGT for pc, make sure you install the "Logitech Gaming Software" from the logitech website =
Logitech Driving Force GT Wheel.
I would of assumed it would be either the start or select button located at the bottom section of the wheel, unless the controls have been remapped... try them all :)
Need manual for driving force gt
Please download the manual link given below
http://www.generalmanual.com/Gaming/Logitech-963293-0403-Driving-Force-Pro-Racing-Wheel.htm
Thanks for using fixya.
Force gt wheel doesnt steer, everything else works fine?
The wheel should be plugged in and powered up before turning on the PS3. While booting the wheel should go through its full range of motion and the horn button light will stop blinking and stay on steady. If the light doesn't stop blinking the wheel failed to calibrate and is probably defective. I had to exchange mine and did end up getting one that worked this time.
USER MANUAL
dont think they do a download for the manual and i have also read on forums that alot of people didnt get 1 when new in box anyway.... i have found it on the net and should tell you all you need to know about what it can do and also how to install and use
http://www.logitech.com/gaming/wheels/devices/4172 hope this help's ;)
