20 Most Recent
Konami Metal Gear Solid 4: Guns of the Patriots Questions & Answers
My copy of mgs4 used
If its the only game that you play then the disc could be getting worn out. It happens with most games that get overused. You will probably have to get a replacement.
Playing through Metal gear solid
It sounds like your disk is scratched. The easiest solution is to go to a video rental store and have them re-surface it (most likely for a fee) or you can go to a store and look for a dvd scratch repair kit (cost between $15.99-$30.00) if neither of these work you will most likely need to buy a new disc
Game works fine until i
If the game works just fine until you're online, it sounds like a problem on Sony's end. In light of recent events and problems with Playstation Network, your best bet at troubleshooting your specific online issue is with Sony themselves. It's quite possibe they are still experiencing PSN problems. Give them a call at:
800-345-SONY
This problem has been talked
Sorry but FixYa does not condone criminal activity such as piracy. It would be best to contain these discussions to boards/forums dedicated to these topics.
My PS3 won't load Metal
yeah i had to restart the whole stinking game because act one : end wouldn't load. not that i was that far into this game but it was a pain nonetheless. I don't know why this happened. I didn't use any cheats or anything like that. I think the "Metal Gear" franchise has gone downhill starting with "Snake Eater" for the PS2. It's sad because this series has so much promise but then all of a sudden Hideo Kojima started with all sorts of weird plots and way way to much dialogue.
Why middle east cant play metal gear online
all online games require an average of 100mbs online connection speed. and the connection you are using there may not be fast enough to connect to the host system. try having the person in the middle east to host a game
Mgs4 problem
thats because you need to press O. Metal Gear is notorious for being backwards from other games.
When I try to connect to the mgo it tells me it
hi its not a problem your end sony are having some problems with their
network just give them time to sort it out and then you should have no
problems click on the link below for more details
CLICK HERE
this problem affects ps2 ps3 psp and the problem is world wide
this problem will be sorted as soon as possible you could try
contacting sony direct to find out how long the downtime is going to be
please dont change ant settings on your console as the problem is with
them and not your console.
give them time this will be sorted out soon
