20 Most Recent Panasonic TH-46PZ800U Plasma TV Questions & Answers
How to fix panasonic viera tc-50x5 wont turn on
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
5/3/2014 9:20:48 AM • Panasonic... • Answered on May 03, 2014
The black colors on the screen ae red
Without having the unit in my shop I would have to say it is one of two things. The power supply or the inverter. You will have to find replacement parts online which will be about 50 to 75 bucks.
4/2/2014 2:38:12 PM • Panasonic... • Answered on Apr 02, 2014
Green snow
A greenish tone to entire display denotes a faulty panel. If you wish to get more details to this, check the site linked here. It has screen-shots to faulty plasma display. You can see it and compare to that of your TVs' and can make sure. Pull up older posts. Good Luck.
11/27/2013 7:07:55 AM • Panasonic... • Answered on Nov 27, 2013
Panasonic tc50x5 no power
turned tv off to put on bigger stand turned of with remote and have tried diffent outlets but will not power on
6/25/2013 4:57:36 PM • Panasonic... • Answered on Jun 25, 2013
No signal shut off appears
check the Antenna and antenna connection (wire ,jacks Etc.)if there is no signal for few minutes it used to go standby.
6/13/2011 7:45:59 AM • Panasonic... • Answered on Jun 13, 2011
Tv screen is flashing on
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
12/12/2010 2:36:29 AM • Panasonic... • Answered on Dec 12, 2010
No action shutoff was activated. How do I turn
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
12/4/2010 10:11:47 PM • Panasonic... • Answered on Dec 04, 2010
The TV will not turn on. When the switch at the
The red flashing light is the service code. My guess is the power supply is bad now, but it could be something else. If the TV is under warranty, take it in and get if fixed. If it is not, then you may try to check the power supply first. Count the flashes of the red light and check online for the issues when this model flashes, 4 times or 6 times... or 9 times, etc.
10/10/2010 6:11:24 AM • Panasonic... • Answered on Oct 10, 2010
I have a 46" Panasonic
Okay if you got a picture under a picture in a background image that mean this TV has once expeience what all TV owners fear and that is Burn in. You have a static image that will not go away that means sometihng got burn in that happends on monitors as well as these have a image and its fixable...
What these other guys say is not correct information.. Read this information and good luck please do accept this advice as I worked hard to get the information for you.
http://compreviews.about.com/od/monitors/a/LCDBurnIn.htm
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
10/5/2009 12:28:51 AM • Panasonic... • Answered on Oct 05, 2009
Random black bar
that bar is a menace to clear. somtimes manufactures put problems in so when you tell them the problem they know what to do this is how they make money
4/23/2009 7:14:18 PM • Panasonic... • Answered on Apr 23, 2009
We have a Pensonic led 3216 led cut, when we try to open it the screen is all black how to fix it? how to do a reset n the tv
Not totally sure what your asking but I think your saying your LED lamps aren't working, if that's the case replace them
10/15/2021 10:33:14 PM • Panasonic TH... • Answered on Oct 15, 2021
0answers
Tx-p42ut50b
Be the first to answer 6/5/2014 12:19:19 PM • Panasonic TH... • Posted on Jun 05, 2014Be the first to answer
Panasonic TH-46PZ800U Plasma TV Logo
19 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
bought our tv from costco in 09 8 19
  • Televison & Video
