20 Most Recent
Toshiba REGZA 46RV530U LCD TV Questions & Answers
Can't find screw size to
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
I have a Toshiba television model number 46RV530U Serial number It takes about 15 to 30 minutes for the picture to become clear. It starts out with multiple images as if seeing double.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
I need a tcon circuit board for a toshiba 42 lcd tv
Me too buddy, me too. I've had an e-mail alert set up for it on eBay for about three weeks now, with no decent results. You should do the same, as I have a feeling it may be a while before one turns up at a reasonable price. I have a million or so saved searches on eBay, and it's the most important resource I have. I can't tell you how many hours of time and frustration I've saved letting eBay do the searching for me.
