20 Most Recent
Toshiba REGZA 32RV530U LCD TV Questions & Answers
TOSHIBA MODEL 32RV530U WILL NOT TURN ON YELLOW LIGHT IN FRONT BLINKS 3 TIMES
This could very well be a problem with the power supply not allowing the TVs to start up but can also be caused by a problem with the TVs firmware. I would suggest downloading the firmware and following the steps from the following link. The download and steps are in the firmware tab after clicking the link. Be sure that even if you have no picture while applying the firmware update that you under no circumstances remove power from tv for at least 15mins. This is to ensure the firmware completely loads. If you remove power while it's still updating the board may be corrupted.
http://support.toshiba.ca/support/ceg/center/en/index.asp?p=32RV530U
Toshiba regza 32rv530u powers on runs fine for a while then powers off?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Tuning tv
Consult the owner manual or Google to find one--if a specific issue let me know.
No ant signal
If you live out of town and away from pretyty much everthing there are few signals that you would get if any. If you live in town than the problem could lie in that you have a very very weak antenna or you have objects in the way of your signal. i.e trees
My girlfriend has a toshiba
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Regza 32RV530U HD TV, dead,
Generally when you see no life at all the problem will be in the main power section or the power source.
The cheap things to try are just to try another outlet as well as reconnecting the power cord. Sometimes those will be just loose enough. If you are very lucky this is all it is.
Normally when the tv is dead the problem is in the main power section or an internal fuse has popped. The power section requires replacement as there are no easy to fix parts on it. The fuses can be replaced but that may just pop again as the cause may still exist. As an example the power supply could have a problem that popped the fuse so if you replace the fuse it will work just long enough to go out again.
What you need to do is check to see if you have any warranty. This might be Toshiba or perhaps a extended store warranty. If you have warranty then you just need to talk to the store or Toshiba or drop it off to a repair depot or authorized service centre. To find out if you have warrenty you need to dig out your sales receipt and call the store. They will tell you if you are covered and by who. If you are not covered then this becomes a bit trickier. This is not a cheap repair so you need to get a estimate only. You also want to know what the price is of a replacement tv. The repair for a main power board can be over $500 (and more) depending on the model. So there isn't any sense to repair it if it's a hundred or so cheaper to just get a new one. Wish I had a better fix than this for you but there really isn't one.
How to widen the screen from a wide screen to full
On your remote you should find a "Format", "Picture Size", or similar button. This should "scroll" through the choices as you press it.
If there is not a button on the remote, access the user menu and look in "setup" and find "Picture size" or "Format" or the like and change it there.
Hope this helps!
What is regza on toshiba tvs and how do i activate
With REGZA link function, REGZA TV remote control unit will be able to communicate with other devices with HDMI-CEC functions connected via the HDMI terminals to operate the functions of connected components like a DVD player and PC. You will need the REGZA remote to activate it.
If you need a manual for your tv, you can get it here:
http://www.retrevo.com/support/Toshiba-46XV645U-TVs-manual/id/23457dj095/t/2/ page 16 of the manual
You can control the basic functions of connected audio/video devices using the TV’s remote control if you connect
a REGZA-LINK compatible audio receiver or playback device. For an explanation of setup and operations, see pages
49.
To connect an Audio Receiver and Playback Devices, you
will need:
•HDMI cables (- page 12)
Note:
• If several devices are connected, REGZA-LINK feature
may not operate properly.
• For proper operation, it is recommended that you use
HDMI cables with the HDMI Logo ( ).
Before controlling the device(s):
•After completing the above connections, set the
REGZA-LINK Setup menu as you desire
(- page 50).
•The connected devices must also be set. For details,
see the operation manual for each device.
•The REGZA-LINK feature uses the CEC technology as
regulated by the HDMI standard.
•This feature is limited to models incorporating
Toshiba’s REGZA-LINK. However, Toshiba is not
liable for those operations. Refer to the individual
instruction manuals for compatibility information.
My captions won't turn on, can you help?
go to menu and look for caption push the caption button if that does not come on plug out the tv for about half hour then plug it in back.if that does not correct your problem that means your on screen display ic is damage that means it is time to get a tech to look on your tv.the problem would be the eprom needs to be replaced.
