20 Most Recent Pioneer DV-310 DVD Player Questions & Answers
2answers
A multi region DV-310 K stopped playing anything but region 2
Check your remote, try and see if you can find where you can default of restore first memory of your set. i think that will help........
5/7/2020 7:06:07 AM • Pioneer DV-310... • Answered on May 07, 2020
Pinoeer display showing GUI
Hi Basha, I can see that the issue you have has something to do with the INPUT of your TV. Find on your TV Remote the button that says INPUT, SOURCE, TV/VIDEO or sometimes TV/DVD ( those buttons are for inputs ) then press it once. You should have input lists on your TV and there you can see again the option "Video". Hope it helps.
5/2/2014 5:44:55 PM • Pioneer DV-310... • Answered on May 02, 2014
Power off while loading
Not worth fixing im afraid.
3/1/2014 10:59:12 PM • Pioneer DV-310... • Answered on Mar 01, 2014
Video is black and white
I have a pioneer dv-353 and had a similar problem.I fixed it by updating the firmware. just search internat for pioneer firmware update download the file and follow the how to.if u cant find it i can email it to u.
5/27/2012 11:17:01 AM • Pioneer DV-310... • Answered on May 27, 2012
0answers
3answers
I need to make PIONEER DVD player DV-310-K region free
I made it today,hurray!!!
Still need help??
5/14/2011 2:00:39 PM • Pioneer DV-310... • Answered on May 14, 2011
Pioneer DV 310 K region free
Step 1) Download the pioneer firmware here http://www.pioneerfaq.info/index.php?question=Firmwares
The site says the firmware only works on region 2 players. For this model it worked for my region 4 player in Australia
Step 2) Burn this file to a CD-ROM with name PIONEER as per these instructions - http://www.pioneerfaq.info/english/burn_guide.php
Step 3) Load the CD and your DVD player with ask you to flash the firmware. It says press play to start but instead HOLD DOWN ENTER during the entire process. DO NOT switch off your DVD during this time. When the tray opens take the CD ROM out but keep the DVD on. The flashing can take up two to three minutes. During this time HOLD DOWN ENTER ON THE REMOTE. The entire time!
Step 4) The DVD player will reboot. The tray should be empty. It will then load the tray back into the player. If the signal is disorted switch on and off.
Your done! Should work.
The most complex way of region freeing a DVD I have ever endured! :)
5/14/2011 1:49:29 PM • Pioneer DV-310... • Answered on May 14, 2011
My pioneer Dv310s was playing
Depends how the region code hack was performed.
It could be a additional chip was used and either chip has failed or wire come off.
You could try unplugging player from mains for a few minutes and try again.
Is it still under warranty from where you purchased it ? If so you may have to return it.
Please dont forget to vote if you liked my answer
thanks
2/11/2011 9:03:52 AM • Pioneer DV-310... • Answered on Feb 11, 2011
Output impedance audio?
hi,
96 kHz/24-bit Audio DAC
ok
1/5/2011 5:20:59 PM • Pioneer DV-310... • Answered on Jan 05, 2011
How do I unlock my Pioneer DV-310-s so it will
Here is how to Make your Pioneer DV-310 regionfree.
Use this link and go there.
Search for file YJA8703A almost in the bottom under DV-310.
Download and burn on CD with nero,make sure the CD is being closed after burning.
The just mount the CD in your DVD player and press play.
#1. Press upgrade.
#2. Wait,don´t touch anything now.
#3. The tray will open after about 5-10 sec,take out CD.
#4. Player will uppgrade under about 1-2 minut,then the tray will close by it self,and the player says "CLEAR".
#5. And now here is the secret. When player says "CLEAR" ,push and HOLD the "enter button on THE PLAYER until it turns off(about 5 sec).
And there you go,standing infront of your brand new Multi regional Pioneer DV-310.
At least this worked great for me.
Good Luck!
/Jiinsen
11/8/2010 4:57:39 AM • Pioneer DV-310... • Answered on Nov 08, 2010
3answers
How to Unlock regions?
Your best bet in saving time for region code changes,is to go to videohelp.com and look for their section on DVDHacks.
Here they have a massive search engine , put your dvd details in and wait to see if you have a code.
Hope i`ve helped.
8/26/2010 7:25:09 AM • Pioneer DV-310... • Answered on Aug 26, 2010
Way i can't see hebrew subtitels all the time?
Not all DVD films have subtitles for all languages. I'm afraid if hebrew is not on the disc menu it won't have it. Next time you are buying DVD's check for the languages it surports. The region code might help you in this. Generally where hebrew is used a lot, the region coded discs for that area will tend to have it on.
7/15/2010 12:37:34 AM • Pioneer DV-310... • Answered on Jul 15, 2010
How to reset back to factory setting dv-310
Power off DVD player, hold down Stop (square) button and power back on until display reads Clear. Viola!
3/25/2010 11:17:44 PM • Pioneer DV-310... • Answered on Mar 25, 2010
2answers
My pioneer dvd player model dv-310 used to be able
We used a usb on the DVD and now we can't watch normal DVDs on it. We insert the DVD and the player just rejects it and opens the draw.
3/2/2010 10:04:39 PM • Pioneer DV-310... • Answered on Mar 02, 2010
Pioneer DV-310 DVD Player Logo
35 questions posted
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
pioneer dv310s playing
  • Televison & Video
