20 Most Recent
Sony Bravia KDL-37M4000 37 in. LCD HDTV Questions & Answers
Please assist with black screen with audio.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Any time I use number 3 my Sony Bravia looses picture &sound
What can I do?
help?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Reset tv sony kdl-37l4000
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
My tv when on turns red blinks six times and off
Not sure if you can see this, but I have a KDL46XBR5 and this is the self diagnostic function listed in the service manual. Six red blinking lights, pause, six more lights may indicate a faulty backlight or a problem related to your backlight. This doesn't necessarily mean you have to replace anything, could be a ground screw is loose, or one of the many cable connectors need to be reseated while the unit is off. See attached to see if this helps. If not, google "self diagnostic function kdl-37m4000" and see if that helps. At least this should point you in the right direction
Sony Bravia KDL-37M4000 37 in. HDTV LCD TV will not turn on
Check its main power regulator section circuit. Replace the power regulator board if necessary.
Visit the site named 'Electro-help' for
more details. Check this link and
select the site named above. View it
in 'Flip card' option, which can
be selected from the drop down box menu at the left top corner or the display
window. It will make search easy. Some times, the ads attached with each posts
might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
37 inch sony bravia color problem
try to play first dvd on you tv on test if the tv has a problem or on just on you digital/analog antenna..If the problem is still there when you play dvd the possible prob is T-con board..hope it helps..please rate..
Tv turns off after playing 15-20 minutes, then it
6 times power/ standby light blink error shows problem of back light inverter board in your Sony KDL-37M4000 tv as per mentioned in related service manual.
Check back light inverter board to fix the issue.
Thanks.
We had a lightning strike
The only fix is to replace the panel and that would not be cost effective. It would be cheaper to buy a new TV.
